Question about HP Scanjet G3010 Flatbed Scanner
I can no longer Scan as a PDF File. Why? and How can I fix that? The dialog drop down menu no longer shows Adobe PDF as a file option.
    President:
  • 1,865 Answers
Reinstall your scanner software
Posted on May 13, 2009
How can I return lost data to Adobe Illustrator CC2015.3 ??
How to repair illustrator file?Place the damaged Illustrator file in a new Illustrator file.
Important: This solution doesn't work if you didn't select Create Compatible PDF File in the Illustrator Native Format Options dialog box when you saved the original file. On the Macintosh platform, the damaged Illustrator file may appear dimmed in the Place dialog box, but you will still be able to select it and place it in the new Illustrator file.
  1. In Illustrator, choose File > New.
  2. Select the appropriate size and color mode, and then click OK.
  3. Choose File > Place.
  4. In the Place dialog box, choose All Formats from the Files of Type pop-up menu (Windows) or choose All Documents from the Show pop-up menu (Mac OS), choose the damaged file, and then click Place.
  5. Name and save the file.
How To Repair ai file
Apr 24, 2018 | Adobe Computers & Internet
I very much like to work with graphic things
https://helpx.adobe.com/illustrator/kb/troubleshoot-damaged-illustrator-files.html
How to repair ai file?Place the damaged Illustrator file in a new Illustrator file.
How to recover corrupted ai file of Adobe Illustrator
Feb 14, 2018 | Adobe Computers & Internet
I like to work with graphics
    There is a manual below or if you no idea where to find recovery file tool for illustrator, when learn next
    https://helpx.adobe.com/illustrator/how-to/recover-files.html
    http://smallbusiness.chron.com/recover-work-illustrator-39270.html
    1. Close Adobe Illustrator.
    2. Right-click on the Windows "Start" button, and click "Open Windows Explorer, then the file manager opens. Navigate to the AI file to delete.
    3. Right-click on the AI file to show the context menu.
    4. Click the "Properties" option. The Properties dialog box opens.
    5. Uncheck (clear) the checkbox next to the "Read Only" option in the File Attributes section.
    6. Click "OK," and close the Properties dialog box.
    7. Right-click on the AI file, and click "Delete" from the context menu. Click "OK" to confirm the deletion. The AI file is deleted.
Nov 27, 2017 | Adobe Computers & Internet
Adobe files not going to the application
Right click on your file, and then select Get Info (or click on the file once, then go to File -> Get Info, or select the file and press Command-I on your keyboard). This will open the Get Info window.
In the Get Info window, the Open With pane displays a pull-down menu with the application that is currently set to open the file. Click on that pull-down menu, and a pop-up list will display all the applications on your Mac that are able to open the file.
Move your mouse down the list and click on the application you want to open your file.
Now that you've changed the default program for this file, the button for Change All is active. This button will set your Mac to use the selected application to open files of this type. Click on that button.
On the dialog window that pops up asking if you are sure, click Continue.
Done. You can close the Get Info window. If you want to change the default application again or change it back to the previous application, just go through these steps again.
Feb 11, 2015 | Apple MacBook Pro Laptop Computer with...
On my new computer my scanner does not list an option for scanning to a pdf file. how can i get that fixed?
Not all scanners or scanner software scan to pdf since it is a file that is attributed to adobe. There are free pdf converters out there you can download. Maybe after installing it it will show up as an option. If not that, you can buy adobe acrobat and it has an option to create a pdf from you scanner straight up.
Mar 07, 2011 | Canon CanoScan LiDE200 Flatbed Scanner
How do i scan to a pdf and save on my pc
  • Scan it as a jpeg or whatever it is scanning as. then you can open the scanned image and
    save as a pdf
  • 2
    Turn on your samsung all-in-one device. Put your document that you want to scan face
    down on the tray of the samsung all-in-one.
    Open your samsung device manager on your personal computer or your Mac. Choose
    the "Scan" function. This will be slightly different depending on whether you are on a PC
    or a Mac andwhat samsung all-in-one model you have.
    Hit the "Scan" button on your samsung all-in-one or the "New Scan" button in the top left
    corner of the software on your computer.
    Click the drop-down menu at the bottom right of the scan window, below the image. Choose
    the "PDF File" option. Hit the "Accept" button. A dialog box that allows you to save your PDF
    in a location of your choice will appear.
    5
    Type a name for the PDF in the "Save As" field. Choose a place for it on your computer with
    the drop-dowm menu. Click the "Save" button. Your scanner will then scan the PDF and save
    it.
Jan 14, 2011 | Samsung SCX 4521F All-In-One Laser Printer
When ever I open any pdf file, it shows that invalid adobe plug-in detected and that file will be closed
Open Internet Explorer on your computer. Make sure no other programs are running.
Click on the "Tools" button at the top of your Internet Explorer page.
Click on "Manage Add Ons" from the drop-down menu that appears. A list detailing the add-ons connected to your Internet Explorer will load.
Click on the Adobe plugin to highlight it. Click on "Remove" to delete it.
Click "OK" on the Internet Options.
Now next time IE will automatically install the Adobe plugin once more and you will be able to view PDF files.
Oct 29, 2010 | Computers & Internet
How to save in acrobat .pdf ?
PDF (Acrobat) files are a great way to make sure documents are viewed with the correct layout and fonts - even when the recipients don't have the program you used to create the documents. It's also a format that is viewable across multiple platforms. In order to create a PDF file in Windows you need to be using Adobe Acrobat Distiller.
Open the file you want to make into a PDF.
Choose File, then Print.
Use the PDFwriter option when printing from a word-processing application: Choose PDFwriter from the Name pull-down menu in the Print dialog box. Fill in the document information, then click Save.
Use Acrobat Distiller option when printing from a page layout or design program: Choose Acrobat Distiller from the Name pull-down menu in the Print dialog box. Fill in the document information, then click Save.
Jan 03, 2010 | Adobe PageMaker 7.0 for PC
HP LaserJet 3050 - can't scan to a pdf format
This is the only solution I found within the software. I went to the actual printer and hit the 'scan to' button. I selected SETUP from the menu options. It pulled up some software on my computer that shows the interface between the computer and the printer. I hit the NEW button. The next screen gave me some options and there was a checkbox option that said 'Show the TWAIN dialog after the scan...'. I checked that box. When I went to the next screen, it offered me PDF as an option and I made that my default. This process sets up a new menu option on your drop-down list when you scan. I named it 'PDF to computer' so I would know to pick it for pdfs. I tried to add it to the list of options available on the printer menu, but the new option I created disappeared after I hit UPDATE. But when I tried to scan something it was showing on my options list. When I tested it, it opened some software I never saw before and showed the image as it scanned, which I guess relates to the checkbox I marked. I've tried several times for hours at a time to find any kind of fix for this that didn't involve converting a file to pdf or loading a different software. This fix I found on my own just by hitting buttons on the printer. If you don't like this option, there is some free software out there that uses the scanner to create pdf's. I just didn't want to go that way.
Jul 16, 2009 | HP LaserJet 3050 All-In-One Printer
HP Scanjet G3010 Flatbed Scanner Logo
273 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
