Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer problem
No matter which cycle i choose, heavy duty, normal, it will stop several minutes later with an error code F H
  • 4 more comments
  • Anonymous Nov 02, 2007
    replaced computer board, water level switch. flow mete n water valve still have same problem getting hf code dont know what else to do.....
  • Anonymous Nov 20, 2007
    Washer does not make it through any cycles and it puts up H F and starts beeping
  • Anonymous Mar 22, 2008
    My washer is not even 2 years old .It started acting up 2 nighst ago.It did not make any softening cycle instaed I saw F and Sud warning and beeping sounds.No load fisnished. And water smells like rotten eggs.
  • MrsBig1 Aug 30, 2008
    Our Duet does the same thing - if you wait a few hours, then re-start, it will go through the cycle fine. Depending on the day, who knows how it will work, but always only comes up with the HF error message. Please help.
  • donna ryckman
    donna ryckman Nov 21, 2013
    My washing machine wash for a few mins beeps then stop so I would unplug then start again thats fine but when it goes to the first spin and before it could go full spin it stop and the wash light beeps until I shut it off. Then I start it again and just when I think it works it does the same thing again only to leave water in the drum it is not draining all the water so then I have to stand there and wring my clothes out before I put it in the dryer. Can any one help or have a soulution for this problem.
  • Anonymous Mar 14, 2014
    whirlpool washer only works on heavy duty cycle
  • 4 Answers
Our machine was giving the HF code at 37 min after over filling with water. I unplugged the machine, popped the top (took the 3 torx screws off the back) pulled the small hose off the pressure switch sensor (round sensor on the upper back right of the machine) and blew it out just by mouth. It obviously cleared some junk. It works fine now. (also unplugged the 6 wires on the sensor, turned it around and blew on that and heard it clicking, so I knew that was ok.) Hope this helps someone.
Posted on Feb 26, 2008
  • 447 Answers
That  means that no water has entered the machine. Make sure water spigots are on, and inlet valve screens are clear
Posted on Oct 15, 2007
Our Duet washer does not seem to be spinning as fast as it should.
Posted on Apr 04, 2010
My washer smells of mildew. I wash almost every day so I know it is not that it is just sitting. Help. How do I fix this problem. I really don't want to get rid of my set but I am going to if I cannot find an answer.
Posted on Apr 01, 2008
  • dave_kamal Sep 13, 2010
    Leave the door open when you are not using it, the door seals so tight that the smell builds up from the water, Start by running it in the rinse cycle with just bleach, once the machine shuts off, open the door and leave it open. I had the same problem with the smell in the washer, it was so bad my towels stunk right after being washed.
Our machine gave the DL and F code then would stop. I unplugged it and waited for an hour then tried it again. It ran for 6 min then did the same thing again.
Posted on Mar 01, 2008
Unplug the washer and wait a few minutes. Then plug it back in and try it. The computer in the system should re-set.
Posted on Nov 01, 2007
Duet washer code f02does not drain and tub not spinning
Posted on Feb 15, 2010
What does error code F20 mean on a Whirlpool HP Duet washer?
Posted on Oct 01, 2009
  • 5050fred Feb 06, 2011
    What does it mean? We just had our water off for a couple of days due to frozen pipes. The cold is now fixed, but not the hot. So we put the washer on cold, but it comes up with an F20 error message. Could not find that one in the manual.
I have a Whirlpool Duet Dryer that is locked on the heavy duty cycle, I cant switch to another setting, it wont cancel out. I've tried unplugging it for some time to reset it. It is still stuck o
when you unplug it you're resetting the computer board just like your house computer does,so if it helped by unplugging it i would have to say the board is bad and needs to be replaced.next time send the model number off of the machine
Feb 02, 2018 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 9100 starts cycle then stops & wont drain
F2 code is a drain issue. If you are not using he detergent you can cause slow draining and then you will get the code. Try using less detergent. Also, try disconnecting the power to the washer to reset controls.
Mar 24, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet Washmachine F11Code
The error code F-11 on your washing machine means:--
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
both this parts needs to be checked.
You will have to check the following to confirm where the fault exactly is:---
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU).
Check the Drive system for any worn or failed components.
Check MCU.
Check CCU.
Check Motor.
Check Wire Harness.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
First, try to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code reappears, then proceed with the steps outlined in the link I provided for you.
This is one of the more "involved" error codes that you may need spend some time with. Although, it may NOT be a difficult repair, it still may require some diligence to figure out the cause. I would recommend checking your washer installation for a potential siphoning problem and then check the drain pump as these are the more common causes. If you require additional assistance, please let me know. I hope this helps you.
Jan 04, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
turn the water supply on,, f/h is a fault occurring when ther is no incomig waterdetected
Apr 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,263 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
