Question about Samsung SyncMaster 173V 17" Flat Panel LCD Monitor
The menu constantly pops-up on my Samsung 17 inch LDC monitor
Is there a setting I need to check?
  • 221 Answers
What does the pop up menu say? I'm guessing it says something like "Optimal settings are 1280x1024, Press 1 to confirm, press 2 to disable". If the message is anything like this, your monitor is trying to tell you that your display settings are less than optimal. You can either disable the message by "pressing 2" or changing your display settings to the recommended resolution. If the menu you're getting is just the control panel and there's no actual message, leave your computer on, reach around the back and disconnect the power cable from the monitor, wait 5 seconds and plug it back in. Samsung monitors sometimes have a glitch and need to be reset.
Posted on May 13, 2009
Have a Samsung SyncMaster 731B (Black) 17 inch LCD Monitor. The screen is black other than a very very very faint glow of the box when pushing the setting and menu buttons. Any ideas?
Might be a case of the backlight giving up. If this is the case, you have two options, replace the backlight (expensive and pretty difficult to do a good job of) or replace the whole thing. I'd go with the second option, as LCD monitors are pretty cheap at the moment! Stick with Samsung SyncMasters though, they do good price monitors that are reasonably reliable too. Either that or a Dell monitor.
Thanks
Moza805
Aug 30, 2011 | Samsung SyncMaster 731B 17" LCD Monitor
I need downloadabdle vga drivers
You can find the same from samsung Website, check in below given site
http://www.samsung.com/in/support/search/supportSearchModelResult.do?menu=SP01&searchWord=SamsungSyncMaster710m17inchLCDMonitor&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=Samsung+SyncMaster+710m+17+inch+LCD+Monitor
May 07, 2011 | Samsung SyncMaster 710m 17" LCD Monitor
Poping up settings automatically
you have to open the back cover and first clean-up the pcb by sucking all dust use a vacuum cleaner check the microprocessor IC clean the area by soft brush then resolder if necessary. check the PCB.
Sep 06, 2009 | ViewSonic E70 17" CRT Monitor
May samsung lcd monitor have no power
Power supply unit might be bad.
Check for popped capacitor.
Mar 28, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor turns black and with a not optimum mode pop-up
Press F8 when you boot your PC, Then boot on SAFE Mode...
Right Click on Desktop>>Properties>>>Settings>>>Advance>>>Check the Apply the New Setting without restarting.
Click Apply then OK
Rebbot the computer to a Normal Boot
Oct 09, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Samsung syncmaster 740N 17 inch no display
manual and drivers
http://www.samsung.com/it/function/search/resultList.do?searchWord=913v&ct=0&sort=0
Oct 04, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
Adjustment pop up's in middle of screen
You should have a p0rogram installed that can do it. It might be listed under samsung in your programs. If not there, look in your video settings.
May 18, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
On-Screen Menu
You have to check keyboard and the cable which interconnect main board and keyboard it could be damaged.
Oct 25, 2007 | Samsung 931BF 17" LCD Monitor
Adjusting Brightness on Acer 17 inch monitor
you change the settings manually using the up and down arrow buttons or plus or minus buttons mounted on the front of your monitor you dont need to use mouse.
Apr 04, 2007 | Acer AC711B 17" CRT Monitor
Samsung SyncMaster 173V 17" Flat Panel LCD Monitor Logo
452 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
