Samsung LCD TV LE26R51BDX - No analogue TV or Freeview
My parents moved house at the weekend. They have a Samsung LCD TV LE26R51BDX which they used to use exclusively for watching Virgin cable 9 [via a scart lead obviously].
In their new home, they do not yet have cable or Sky. ''No problem'' I said, ''we will just connect it to analogue and/or Freeview through the rooftop aerial''. However, although I am 99% sure that I have followed all the correct menu controls:-
1. The TV picture is just really fuzzy black & white images [although it is picking up faint images & audio].
2. The DTV [Freeview] option just states that there is no signal.
I know that the problem is not the aerial or the cable because I substituted the Samsung LCD with a small portable TV and tuned in the analogue channels in seconds with super clear picture & audio.
Lastly, although I am not certain it is relevant, they purchased the TV from PC World [as a monitor???].
I am usually pretty techno savvy, so this has been a real puzzle. Any ideas would be really appreciated [and would save my reputation as the family IT guru].
Thanks.
Martin
  • clive pearson
    clive pearson May 11, 2010
    Hi You say they purchased the tv from PC world as a monitor . did they pay a reduced price Ie: mangers specia; by any chance ?... Regards Vortash
    Top Expert:
  • Televison & ... Master
  • 80,531 Answers
Are you sure the TV has a built in tuner? Does your country have digital over air broadcasting like my country or not?
Posted on Mar 03, 2017
5 Suggested Answers
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
SOURCE: Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Posted on Apr 30, 2008
SOURCE: Can't tune in my Samsung DTV channels
WDDW
Posted on Nov 17, 2008
  • 458 Answers
SOURCE: I have just moved house to Reading and previously
You will need to have an outdoor aerial installed, the signal area you're now living in will not be a strong enough reception for an indoor aerial no matter how good or expensive. You could try the indoor aerial in different positions around the room especially by a window to try & pick up some other channels but the long term this will cause some of the programmes to break up or freeze. An aerial on the roof or in the attic will be your best solution to pick up all the digital channels on freeview.
Posted on Nov 15, 2009
Tv connected via scart cables through dvd and virgin media box. Picture sometimes goes yellow the flickers then back to clear.Other times it can go red. Plays dvd's okay though. Is this a connection...
This will be a problem with either the Scart leads (9 times out of 10) or the virgin media box. Not a problem with the signal coming from Virgin Media. Try checking the scart leads are not loose, or looped through the wrong way.
Hope this helps
TV_Doctor
Jan 03, 2011 | Sharp LC-32P50E 32 in. LCD Television
Have samsung 40inch lcd colour no good on ext 1 and 2 but on hdmi via virgin fine want to play dvd but no good on ext 1 and 2 will new hdmi dvd be ok via hdmi cable instead of scarts
Correct you wiring, color stream uses red, blue, green and they have to be hooked up correctly. the problem is obviously not in your tv or the DVD player.
Nov 08, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Virgin cable installed, how can I get it to other rooms?
Buy a spliter and install it on your line out (to tv) on your cable box. Now u have two lines out, but both tv sets must watch the same chanel
Apr 28, 2010 | Televison & Video
My Samsung TV picture is supplied via a HDMI lead
yes you need to connect audio out from the tv to audio in on the dvd surround. you need the red/white phono to phono leads, simply connect together and select audio (av,au) on the input selection.
Feb 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Samsung 2333HD to dvd/vcr combo
On a DVD/VCR combo unit....the Component Output (RED, GREEN, BLUE) is exclusive to the DVD player section only (VCR can only output analogue source) and will only be able to view DVD.
To watch VCR, you will need to connect to your TV via Composite (YELLOW) cable, into the Yellow AV input on your TV. You can then tune the VCR section to match your TV's RF input (if you prefer this connection).
Good luck...
"if this has helped you, please rate this solution"
Dec 04, 2009 | Samsung SyncMaster 2333HD 23 in. LCD TV
How to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Nov 01, 2009 | Televison & Video
Stereo Sound on new LCD Samsung Series 5 TV
It appears you may be using a cable type which isnt compatible with stereo. The Coaxial output on a lot of the old VCRs dont always support stereo so that may be your problem right there. i suggest you try connecting the cable box directly to your TV using a scart cable. Scart definately supports stereo audio so if this doesnt give you stereo sound the problem lies within the cable box's audio settings which you should be able to access with your remote.
ope this helps you solve your problem :)
Good Luck.
Jun 15, 2008 | Samsung HCJ655W TV
Televison & Video Logo
238 people viewed this question
Top Televison & Video Experts
