Question about Dryers
Dryer won't start up
Empty water tray and clean filter icon stay lit and appliance won't work anymore on hotpoint ctd80
  • 1 more comment
  • damian337 Sep 15, 2008
    same for me
  • Anonymous Oct 10, 2008
    same for me too, anybody help with this??? thanks
  • Nicholas Horn Jan 02, 2009
    i have the problem too..
Does it beep 3 times when you try to switch it on?  If so the door switch is faulty.
Posted on Feb 23, 2008
Ctd80 hotpoint dryer panel flashing dryer not working
Filter at bottom of machine needs pulling out and cleaned on a regular basis. This is a common fault and the lights is telling you to clean the filter. It is a large filter that unclips at the bottom front of machine. Remove two small screws from the front of the filter located left and right and gently remove the front plate. Once removed you will see a metal filter clogged with clothing debris. Clean with cotton buds and a damp cloth till clean. replace all parts and you should have it working once again with a good heat source as well. Every 2-3 months is sufficient to keep it cleaned. Hope this helps.
Feb 27, 2014 | Hotpoint Dryers
Empty water light, empty condenser
I experienced the problem with a hotpoint TCYM 750, with the red empty water light failing to switch off. After removing the filter and cleaning it, cleaning the condenser and drying anywhere I had access to the machine still didn't heat and the light remained on. Reading the post about the machine having 3 reservoirs it struck me that one of the reservoirs may be hard to access. So I unplugged the machine and tipped it onto its front. The reservoir drained, I pushed the machine back upright and cleared up some water around the condenser. The drier now works properly and the empty water light is off - job done!
Feb 04, 2014 | Hotpoint Dryers
My Hotpoint condenser tumble dryer TCD980 won't dry.
hi ime not sure but some dryers have a small tank inside at bottom with a float maybe float is stuck or if it has a pump maybe not working will have one if water tank is at top of dryer
Feb 05, 2013 | Hotpoint Dryers
Why does it take hours for the empty water light 2 go off
take that water pump off and clean it.this worked for me
Jan 22, 2009 | Hotpoint TDC32 Electric Dryer
Empty water light stays on
Remove lower left filter,and washout under running water, reach into the opening and clear out all fluff and gunge, get a plastic bag tie or similar, and feel for and locate small hole at rear of compartment and poke clear with plastic
Make sure the air vents are clear back and front and try again, if still showing light then probably the float switch is sticking or faulty, this involves a complete strip down of dryer to fix.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint TDC32 Electric Dryer
Empty water light staying on machine will not work
Probably sticking float switch
Remove lower bottom left filter completely run water thro it to clean all fluff out reach inside and clear any build up of fluff that you can see or feel.
At the back of this aperture is a small hole that gets clogged up,feel for it and poke a plastic bag tie or similar, and poke it clear, if this does not work then it would probably involve a strip down to access the float chamber and switch assy.
Thanks.
Dec 13, 2008 | Hotpoint TDC32 Electric Dryer
I have a hotpoint ctd80 showing error f13, have cleaned all the filters, and cleared the water and still it doesnt clear error on the low heat setting
F13 indicates the rear thermistor is open/short circuit, this is part of the heater circuit. it is akin to a thermostat, but there is more than one!!
Hotoint recommend you call an engineer..
I am assuming that this is a lcd tumble dryer.
Plz leave feedback.
Ta.
Dec 10, 2008 | Dryers
Hotpoint Ultima CTD80
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Sep 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Dryers Logo
262 people viewed this question
Top Dryers Experts
