Question about Ricoh Office Equipment & Supplies
E6 error On a Ricoh ft4022 copied paper doesn't throughly comes out
  • Anonymous May 11, 2010
    First of all you need to press the "." key to read the last 2 digits, so the code will be "6 xx".
    Please provide the entire code, but I can tell you that codes that start with a '6' are usually main board problems, but I can provide further advice if you provide me with the whole code, and also let me know if you have a sorter installed.
  • 203 Answers
It can be some of this because you give us only the firs digit you should press "." for to see the two other digits which can be as follow:
E620 Main board – ARDF communication error
E621 Main board – Sorter communication error
E623 Main board – Paper tray unit communication error
For start you can see do the sorter or the ADF are good connected
It has two cables one is white and other is black see do they are good connected or it can be broken on some place of the cable, special the black because is optical cable.
also see do the paper tray is good entered in the machine if all this up mentioned are good then is a problem with the main board
Posted on Jul 12, 2009
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
I keep getting the following error message: E6 F2 - what does this mean?
If you have a Whirlpool oven, the F2 E6 error means that the Cancel key line is open. You will need to replace the keypad or the keypad and controller board (if a single assembly) if the keypad doesn't respond to a press of the Cancel Key.
I hope this helps.
Dec 12, 2011 | Whirlpool Ovens
How do i solve ricoh ft4022 E-5 error
E5 is the error of the fusing unit chech the thermistor
Oct 12, 2010 | Ricoh Aficio 2015 Copier
We have replaced our thermistors in our Ricoh FT4022. How do you reset the code?
Providing that the thermistors are good and they have been installed correctly,here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad fusing lamp or a bad connector.
Oct 02, 2009 | Ricoh Office Equipment & Supplies
RICOH FT4022 BIG STREAKS THRU COPY
Most likely you are beyond cleaning. Sounds like either your fuser, or drum is causing problems, and even if it is simply optical, there are a few different service mode adjustments that need to be performed after cleaning to correct the image density, which are too complicated to explain here. There must be a local service company that will help you out on this one. I myself, still work on a few of these machines, and although they are old, they are still worth putting a few dolaars into if it is serving your needs. They were/are an excellent model. Sorry I can't really give you any direction, other than to advise you that you'll be needing a tech to get it working properly.
Mar 05, 2009 | Ricoh Office Equipment & Supplies
Ricoh FT4022 error E-1
E1 Exposure Lamp problem. (sensor, lamp, lamp stabilizer)Either the lamp is blown, the board is bad or the sensor is bad.
Feb 12, 2009 | Ricoh Aficio 1035 Copier
E1 ERROR ON RICOH FT4022
Nov 11, 2008 | Ricoh Aficio 1035 Copier
ther is arest of this error code you can get it by pressing (.) key on the panel to read 2 numbers and then report again
Choosing a paper type
Un fortunately it is often a trial and error thing. I would try all "special settings", even cardstock ect.
Mar 17, 2008 | Ricoh Aficio SP C410DN Laser Printer
162 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
