Question about Sharp AR-275 Copier
Cannot clear stored fax data?
Sharp AR-275 Cannot clear stored fax data? It is unable to receive faxes. It rings three times and then stops.
  • 3 Answers
Look in the fax manual there should be a section on that
If you have no manual call the company where the fax machine was mad.
Posted on May 13, 2009
Clear incoming fax memory
Please check all the fax setting?
Jul 31, 2013 | Sharp AR-M237 Copier
Not receiving fax
check the mode of receving auto or mannual change the ring pattern.
Jan 14, 2010 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
I have a sharp ar-m455n and it is stuck on 59% memory on the fax. There are no faxes pending it has been like this for quite a while. Repairman says its ''normal'', but I have had 100% memory before. what...
Something the fax received into memory has corrupted its RAM or it received bad data/info. You can clear this problem by going into service mode by pressing the following keys : (PS. you must be in copy mode) P * C * then enter 66 and "start" then you can use "7" to try and print out what is stuck in memory or enter "10" to clear out the image memory then press "start".
Reset copier after that and you should be good.
Mar 22, 2009 | Sharp AR-M455N Copier
Sharp AR-275 copier with fax module. Need to edit sender ID
push custom or system setting button, push key operator programs on lcd, type in 00000 from number pad, hit fax settings, fax default settings, own name/number set. hit ok button at top when done then CA button to return to main menu.
Mar 04, 2009 | Sharp AR-275 Copier
I want to receive fax message with just one incoming ring.
press the following
function-7-monitor button 4 times, then start [*]- should say service mode then press 1 then 4-5-then start-start - clear then 1 then start then stop - stop
Jan 20, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Fax is not Receiving
Unplug the power cord for 10 seconds.
Do you have DSL or any other kind of digital phone service?
Oct 16, 2008 | HP 1040 Plain Paper Inkjet Fax
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Unable to Receive Incomming Fax's
I need help with my MFC 240 c Brother printer. I cannot send faxes or receive faxes. I do not know how to set the setting. Plus I lost my book that went with it.
Feb 07, 2008 | Brother Multi-Function Center MFC-240C...
Sharp fax to receive
Switch off the fax. press the stop key and power up the fax again, keep pressing stop button. memory clear will appear. press start and the memory will clear.
enjoy
Viren
Nov 25, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
Sharp AR-275 Copier Logo
130 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
