Question about Panasonic KX-TG1033S Cordless Phone
All 4 handsets note "busy" and there is a sound like a busy signal. What gives
  • 15,935 Answers
CLICK HERE for your owners manual in PDF format.
CLICK HERE for the troubleshooting section.
"BUSY" in the display means -
*The called handset is in use.
*The handset you are calling is too far from the base unit.
*There is no handset registered to the base unit matching the extension number you entered.
*Other units are in use and the system is busy. Try again later.
Remove the batteries form each handset.
Replace them one at a time and check for proper operation.
One may have become unregistered when a battery died - or power outage.
See page 35 of the manual to un-register and re-register them to the base.
Thanks for using FixYa - if you require further clarification, please use the "Continue With This Expert" option so we are connected in the future.
Thank You :D
Posted on May 13, 2009
All phones are plugged in and operating but i get a busy signal on all in talk mode
I assumed when you say all phones are operating means there's power and are charging.
1. There could be some phones that are loading the Tel line. Disconnect all phones and plug it one by one while checking the dial tone. If all phones gives busy tone, there coulb be a problem in the Trunk line or the Tel Company line.
2. There could be a short or resistance in the line. Check the connection in junction box between your house and the Tel Company cable.
3. If you have an analog Tel set, you can check the dial tone directly from Tel Company cable that comes in to your house.
I hope this helps.
Best Regards.
Sep 01, 2015 | Panasonic KX-TGEA20 Additional Digital...
Constant busy signal
Has this constant busy signal just started or has it come recently? If you've got a space receiver/handset use it to replace what you've got connected at present. If fault persists then it's not the unit that's at fault but the line's faulty and needs reporting to the service provider. If the fault went away when you changed the unit then you know that the problem lies with the handset/receiver or whatever you call it. Decide what to do in this case-probably get a better handset.
May 06, 2015 | Lands Phones
Why made phone early now cant just get busy signals?
Sounds like your phone or line is now short circuit and is holding the line so it appears busy to incoming callers. Try disconnecting the pnone and line right up to the incoming point of your house to find the problem.
Jul 30, 2014 | AT&T CRL82312 3 Handset Answering System...
Password to delete all contacts from phone
You might need your phone's security code to do that! But I guess you forgot the code? Nothing to worry though, you can try these steps below:
  1. Turn off the handset and remove the SIM card.
  2. Turn on the handset WITHOUT the SIM card.
  3. At the Insert SIM card screen, enter *2767*2878# (that is, star 2767 star 2878 pound).
    If fails please try code *2767*3855# (that is, star 2767 star 3855 pound).
    • NOTE: The handset now resets to factory settings. This erases all downloaded content as well as pictures, text messages, and phone book entries that are saved to the handset.
  4. The handset automatically turns itself off and then back on, and then it returns to the Insert SIM card screen.
  5. Turn off the handset and insert the SIM card.
  6. Turn on the handset.
    • NOTE: It may take about one minute for the handset to find a signal after this procedure. After it finds a signal, the handset should then function as expected with the security code set back to default (00000000 8 zeros).
  7. Or if the steps above didn't work, try visiting this link
Aug 10, 2010 | Samsung Star GT-S5233 Cell Phone
How can i use internet on my pc through my sigmatel s66 handset?
Go to your service provider or look for data cable where you can access internet with it. Some data cable has an installer with it. Install appropriate program to your PC. connect your handset to your PC as your server. Note: some handset don't operate with zero credit on the account for an airtime or when it is beyond the reach of the handset source signal.
Jun 21, 2009 | Handmark Software MobileLists (950142) for...
No dial tone/ others trying to call get busy signal
there is no problem with your phone.Because the main problem is the simcard you are using...try to buy a new simcard
Jun 20, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Busy signal, phone states ''line in use.''
Make sure the handset is set in it's cradle. But it sounds like some other device is on the phone line.
Nov 13, 2008 | Brother IntelliFax-2480C Fax
A busy signal
Hi Kevin,
Sorry for being off line so long. If you have not fixed the problem already, I would try de-registering the handset 3 (from both the base and handset), then re-register it, it should re-register as HS 3, unless 1 and 2 are vacant. If that does not do it, de-register just the handset (not at the base), then re-register it to the base, it will grab the next sequencial intercom number. If it is still failing, then the handset is most likely defective. As a last resort, you can try initializing the handset and the base. Let me know how it goes. CG
Apr 03, 2008 | Panasonic KX TGA400B Cordless Expansion...
Panasonic KX-TG1033S Cordless Phone Logo
503 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
