Question about Intel D101GGC Motherboard
I need help choosing a video card - part 2
Whats the difference between PCI video cards and PCIe video cards?
I found 2 PCI video cards the same card but with different memory
I already maxed out my motherboard's system memory (2gb) so do I get the higher 256mb, or the lower 128gb video card both are Diamond Stealth Radeon 9250. Note I need to know why PCIe is better than PCI.
  • rebel371 May 13, 2009
    So how much video memory is too little? And whats the difference between PCI Express x16 and PCI - sorry I meant to type PCI Express.
    Thanks.
  • 221 Answers
PCI and PCIe are slot/bus types. Near the bottom of most motherboards, you'll find anywhere between 1 to 6 expansion slots. These are where you add the video cards, modems, network cards, USB cards, sound cards, etc... Each type of slot has a name. Video card slots are usually at the very top, these used to be AGP slots, with PCI slots below them. PCI slots are normally white. AGP slots are normally green or brown. PCI slots were standard for many years because of their versatility and speed. In recent years, the PCI standard was upgraded, and two new standards came out of it - PCIe and PCI-Express (not the same thing). PCIe slots are faster, and much smaller. They're normally black in color. You can think of PCIe as "PCI 2.0" or "PCI - the sequel". As for a video card, the type of card you get is dependant on your motherboard. You can't use a PCIe card if you don't have PCIe slots. Likewise with the PCI card. Once you've determined the type of slot/card you can use in your machine, you then should pick the card with the most RAM you can afford. You can never have too much video RAM, but you can often have too little. The Video RAM has no effect on the system RAM (motherboard RAM) until you get to 4GB of system RAM. If you're running Windows XP 32bit, you're limited to 4GB of RAM, but the OS will reduce that depending on your video RAM. It's a long story. Anyway, hope thie helps.
Posted on May 13, 2009
  • Sphynkter
    Sphynkter May 13, 2009
    PCI-X lost the battle to PCIe. PCIe comes in different versions, which pretty much only differ by speed of the bus and how much data it can move through the bus in a given amount of time. If you're playing video games with 3D rendering (most modern games) you should have no less than 128MB of video RAM. The more intense the game, the more RAM you'll need. If you have a 128MB card and a 1GB card and all other variables stay still, the 1GB card will give you smoother pictures and faster frame rates. The 128MB card will still work, but just not as well. You can read up on the technical details and history of the PCIe standard here:
    http://en.wikipedia.org/wiki/PCI_Express
  • 909 Answers
PCI is the older, slower format, PCIe is newer and faster, but your system MUST support PCIe or it won't work.
So easy option is to find if your system supports PCIe and then get whichever is suitable.
How to add a card
open the case up then pull a slot out of the case then put it in put screw in card slot then power up then put in drivers for card
Aug 13, 2014 | Computers & Internet
How to install Pci-e 16x in a pci slot
Do not put a PCI-e card in a PCI slot. It will not fit and the card won't work. The PCI card has 58 or 60 pins on each side with the slot (62 pins would be present if not for the key notches for alignment). PCIe 16x cards have 32 pins.
There are adapters to put a PCI card in a PCIe 1x slot (will fit any PCIe slot) or a PCIe1x card in a PCI slot. See http://www.amfeltec.com/index.php for a sample of the adapters. For the PCIe 16x cards, you need a new motherboard.
If you are placing a PCI-e 16x card in a PCIe 16x slot or a PCI card in a PCI slot, then open the side of your case. Locate the matching slot (remove the current card) or an empty slot depending on your motherboard. Depending on the case, you may need to remove a screw to remove the old card. Wiggle the card straight up to remove it. If you are putting in a new card, you will need to remove the cover from the slot. (For some larger PCIe 16x cards, you need to remove the adjacent slot cover as well.) Some covers just pull straight up or pry a lever up and then pull; for others, you will need to use a screwdriver to break the cover out. Make sure there is sufficient room near the slot for the card. (You may need to move other cards around.)
Then line up the card so that the back of the card will fit into the opening and the contacts on the bottom of the card are above the center of the slot. Firmly press the card down into the slot without changing the alignment. You may need to wiggle it (press down on the back and front, alternatingly). Then make sure the card is fully seated. Attach the addtional power cord from your power supply, if needed for a PCIe 16x card.
Close your case. Then if this is a new video card, turn on the computer and enter the BIOS (press F1, F2, F10, Esc depending on the machine). Disable the on-board video. Then reboot the computer and load the drivers you need for the card.
I hope this helps.
Oct 16, 2011 | Computers & Internet
Hi, I have Intel DG965SS MOTHER BOARD and wanted to add a video card , how can I know what video card can I use ?
Hi yair_osman,
Install PCI Express [Graphics / Video Card]
You can install {Any Type} of PCI Express Card.
It 'must be a [16x PCIe] card!" the "lowercase" (e) = Express.
Important!: It "must fix the {Form Factor} of your Desktop!"
Meaning: "The "Dimensions" in (inches)
Go to the "Website" below.
Its for your Desktop "Assembly Guide"
This is an example of a PCI Express Card:
Galaxy 43GGS8HX3SPZ
GeForce GT 430 Video Card
Price: $69.99
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here for "Manual: http://downloadmirror.intel.com/15054/eng/DG965SS_TechProdSpec.pdf
Mar 13, 2011 | Intel DG965SS Motherboard
I have the Board ASUS P5VDC-MX. And I wonder that there is no pci-e slot, but in the information there is written:"this board is pci-e (16x) ready".... is it right ? Can i use a pci-e (16x) video...
No, you can't use a PCIe x16 card in any of the slots on the P5VDC-MX board. A PCIe x16 card can't fit into the PCIe x1 slot. Attempting to force a PCIe x16 card into the PCIe X1 slot will break the card or bend the pins. A PCIe x1 card will work in a PCIe x4, x8 or x16 slot, though. Similarly, the AGP and PCI slots are not compatible with the PCIe x16 card design.
I wish that I had better news for you.
Aug 19, 2017 | ASUS P5VDC-MX (P5VDCMXGREEN) Motherboard
How can i tell the difference between pci slots and pcie slots
The Peripheral Component Interconnect or more commonly known as PCI is a standard for connecting a lot of devices inside your computer to extend its capabilities. Devices like sound cards, modems, NIC, TV Tuners, and some video cards have at some point or another have used the PCI port.
PCI express ( PCI-E ) is a much improved version in terms of speed. PCIe uses a serial interface instead of the old parallel interface used by PCI. It also utilizes individual buses for each of the devices connected to it instead of a shared one like what PCI uses. The difference in speed is quite huge when comparing the standard PCI slot which runs at 133MB/s to a 16 slot PCIe that can send or receive up to 16GB/s.
The most common use for PCIe nowadays is with graphics cards which benefits hugely from the huge bandwidth provided by the interface.
1. PCIe is much faster compared to PCI.
2. PCIe uses a serial interface while PCI uses a parallel interface.
3. PCIe speed is classified into lanes, each capable of delivering up to 1GB/s data transfer.
4. PCI slots are standardized while PCIe slots vary depending on the number of lanes the slot is intended for.
5. Despite PCIe superiority, most manufacturers still use the PCI standard for their devices.
Unlike PCI slots which are the same size for all devices, PCIe slots can differ depending on which form factor it accepts. The longest would be the 16 lane slot and understandably, the shortest is for the x1 devices.
I hope this much information is enough for you to understand the difference between both of them. If you need any more help let me know.. !
May 13, 2010 | Dell Dimension 3000 PC Desktop
Ok, i have two things to ask 1: Where is the video card on a emachines W3503? 2: Could a video card swap be done between a W3503 and a W3052? Thank you for viewing :)
1. The emachines W3503 has an integrated ATI Radeon™ X300 based graphics card. It has also a PCI Express (PCIe x16) slot available.
2. The emachines W3052 has a NVIDIA® GeForce®4™ MX graphics card. I'm not sure whether it is integrated or not, but I'm sure that if it is not, it will be an AGP graphics card. Since The emachines W3503 has a PCI Express (PCIe x16) slot available for installing a graphics card, the swapping of graphics cards between the 2 machines is not possible since they support different types of graphics cards.
Jul 11, 2009 | Computers & Internet
I need help choosing a video card.
Hi there.
Any PCI Express card will do as long as its DDR2, DDR3 is not supported by your motherboard.
You have a choice between ATI or Nvidia graphics cards and your system should support up to 1GB of graphics memory.
Good luck and thanks for using FixYa!!
May 13, 2009 | Intel D101GGC Motherboard
How do i install a better graphics card
Start by Identifying what type of Card you need to buy. The Manual would be Extremely helpful in identifying What type of Video card slot you have. If that option is out you can look in the device manager and that should tell you what type.
There are many types For any modern Cards your Hoping for an AGP or PCIe Slot bare minimum you need a pci slot.
If you have a Vesa or ISA slot you'd be better off spending money on a new Motherboard & CPU
Once you know what type of card to buy PCI, AGP, or PCIe go out and look for the best card that fits your budget and that your PC meets its requirements
Most new Vid cards require a power supply connection or sometimes two or a special power supply adapter in addition to the available card slot PCIe comes in different speeds x1 x8 an x16 Make sure you have the right one that your card needs before buying. AGP likewise comes in 2 varieties AGP and AGP2 they have a different pin count on their edge connector so make sure what connector it has. PCI just about every semi modern PC has at least 2 PCI slots question is are the currently filled with other cards
Once you've purchased your card, you need to determine if you have an integrated video card.
This would be a video connection that is built into your motherboard.
If you do then you need to look up how to enter your BIOS to disable it (Usually pressing<Delete> or <F12> during boot up. Then go through and change the on board video card to disabled
press <F10> to save and exit
power down PC
Unplug power cord
Remove case cover and install new Video card
Replace case cover and plug back in
Boot up PC
Get Operating system up
insert the CD that came with the new card to install drivers and utilities (Another alternative is to go to the website for the GPU or card manufacturer and get the latest drivers) [ often times the drivers on the install disc are already outdated]
reboot ....... Congratulations your need Vid Card is install Now go play that game your dying to beat ;)
Hope this helps
Dave
Nov 07, 2008 | Gateway Computers & Internet
Fastest pci slot?
Hi stevebise, no not at all. The 2 white PCI slots on the P5LD2-VM run at the standard PCI 2.2 speed. Which is 32 bit at 33.33MHz or 133MBs. How ever your board has another PCIE port which is double the speed of a standard PCI port. This is what a PCIE 1x nic card looks like;
http://www.provantage.com/startech-st1000btpex~7STRN021.htm See page 1-22 in your manual.
If your current network card seems to function in the white PCI slot as a (KillerNic), than why buy a PCI 1x nic. As they say, "Ain't broke, don't fix it".
Hope this answers your question.
Mike
Sep 13, 2008 | ASUS P5LD2-VM Motherboard
HELP FINDING A CARD TO FIT MY PCI SLOT
It is easy to get the PCI & PCIE stuff mixed up. PCI slots are all white doesn't matter who makes the board. PCIE however is all together different from a PCI slot. The PCIE slot sits fauther away from the back of the computer & so does a AGP. PCIE is a very long card. A PCI is not. The short slot you saw is also a PCIE slots. Not for video but more likely for network card. Most people never use them. Most likely the long slot above the short slot is a PCIE. So you want a card that is like what I'm going to list in this link.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=1559&Nav=|c:1558|&Sort=0&Recs=10
Please list the model number of your Dell & I can tell you exactly what video card you need.
please vote... I'll check back in an hour or two.
Feb 16, 2008 | ATI RADEON X1650 Graphic Card
Intel D101GGC Motherboard Logo
156 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
