Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips Visual Problem
Green color on bottom of screed. Hard to see. Not clear
  • Anonymous Jan 10, 2008
    I had the same problem with a co-workers 60PP9202. I replaced the convergence IC's and it works perfect.
  • 1,694 Answers
Probable convergence involves
1)pull chassis
2)replace convergence IC's STK392-110 x 2
3)reset alignment
Usually,a 400.00 repair at a tv shop.......T.
Posted on Oct 25, 2007
Corner of picture is out of focus with colors separated how do i adjust the images
The Philips and Magnavox sets have a way of the anti freeze going cloudy in the green and blue guns. Look (with a pair of sunglasses, while the set is running)) into the lenses, and make sure there is no haziness in the coupling lens (the lens the liquid makes up). This anti freeze keeps the CRT cool since they are run fairly hard, and generate lots of heat.
I have done 2 Philips sets just this week for anti freeze trouble. It should be clear as water, if it is not, that is the trouble. Your trouble could be that the anti freeze levels have dropped, the top of the coupling lens chamber, when the projected image hits the front of the set, appears at bottom of the screen. The image will be out of focus in the area where the anti freeze is gone.
Aug 15, 2010 | Philips 55PW9363 55" Rear Projection...
My tv color is very red and orange but all 3 color bulbs are working it seems... the actual picture only comes through the red and green... help!!!
go to and order the kit that replaces the fluid in the blue and green bulbs, will clear up your color issues no problem :) i just fixed mine, now it looks great.
May 10, 2010 | Philips 55PP9352 55" Projection Television
I've got a Philips 50P8341A Projection 50'' TV. My problem started with the screen only showing an orange image. The picture was clear and sharp, but there was no color other than orange. So I tried to fix...
Turn the top left knob down till the pic comes back and the reason your color is off is the fluids in the green and blue chambers needs to be changed.
Nov 12, 2009 | Philips Televison & Video
Green red bow top bottom picture not clear
you need to replace the convergence IC's not really a hard project for a DIY er just do not buy cheap STK IC's as they will not last
Larry D
Aug 14, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color lines in tv screen
it's an lcd filter fault it's betwine lamp and screen before mirror, seems like u will need to replace it but it hard to say without look at it.
Mar 22, 2009 | Philips 55PW9363 55" Rear Projection...
I need to know the color code of my 2000 ford f150 radio
Look in the driver's side door jamb. There should me a sticker with the details of your truck.
At the bottom you'll see EXT PNT:
Mine says EXT PNT: SU
I believe SU is the the color code. You can probably order the paint from the dealer, or any good paint supplier can get you the equivalent.
Remember that paint can fade and change color over time, so if you're not a pro painter, blending the bright, new color will be very hard to do; you might as well just paint the entire panel or the whole truck if you're not already going to.
Feb 27, 2009 | 2000 Ford F150 Flareside SuperCab
Ws 55511 convergence lines bowed down at bottom of screen
Check resistors might have cold solder joints are changed resistance values around replaced STK393-110
Pay attention to faded colored or fried resistors.
You can download service manual for WS-55511 from HERE to get schematics and technical info. (download all 3 parts of file and use WinRAR to extract file)
Good luck.
Dec 13, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Philips 19" monitor. volume control
damage to the board internally you need a new vga board may be a main board but I think it needs just a vga board.
May 07, 2008 | Computers & Internet
Warped Picture, Separated colors
Each color (red,green & blue) has an amplifier IC (STK-).
When there is a convergence issue,the first step is change both
IC's for reliability. Then check for open fuses devices,usually
pico fuses.Then re-check convergence alignment.......T.
Feb 07, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
49 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
