Question about Estate TAWS800JQ Top Load Washer
Washer will only spin with light loads. When
Washer will only spin with light loads. When there is too much (normal load) it will not spin or spin slowly washer is a estate taw s800 jq1
I replaced the clutch and the problem seems to be fixed
Posted on May 14, 2009
Frigidaire front load washer will start and after about 2 seconds will stop. Lights will go from normal working to no spin
From what you have described I would have a professional diagnose the unit's timer and main control board for possible replacement of those parts.
Aug 31, 2012 | Frigidaire FTF2140FS Front Load Washer 10...
Have a Kenmore 20902 top loading washer. Does aggitate in wash cycle, but wont spin in rinse. With drum empty, it will spin. Removed cloths, rung dry by hand and returned to drum. Still would not spin, but...
Your drum is in a sense sitting on a barring , it sounds like your barring is going out. Works with no weight, and if helping as you said. Normally means barring is worn out and can not handle any weight.
May 08, 2011 | Kenmore 22422 Top Load Washer
Extract not working...motor humming...wash is normal..
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin. This is a new problem this evening. With a load in the washer the normal high speed (or any other speed) spin is not working. We've checked the load - which is OK. Suggestions?
Is it draining the water,water has to get to a certain level before it starts to spin,even with all this fancy new gadgets it still goes by the basics.lol
Oct 02, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer will drain but will not reach full spin in spin only mode
they dont spin full speed if they are overloaded, try it with less clothes.
Feb 11, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Clothes come out extremly wrinkled on top loding whirlpool washer
This is normal. You can try a lower spin setting or smaller loads. The wrinkles will come out in your dryer.
Jan 19, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer will not spin
normally i would suggest changing motor carbons for hotpoint washers, but my experience is that the WMA motor armature is weaker than the carbons, normally if there is no connection fault a replacement motor is the answer 9 times out of 10, not a job for the amature
Aug 28, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Estate TAWS800JQ Top Load Washer Logo
259 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
