Question about Sharp R-820B Convection/Microwave Oven
Dark streaks at bottom of glass door on microwave.
  • Sharp Master
  • 9,098 Answers
If they are inside, you can take the door apart to clean it without removing it.
You can watch a YouTube video (not a video I made) that demonstrates how it's done.
Also, we have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
Posted on May 13, 2009
How do i take a ge microwave door apart to remove a piece of paper between the two glass panels ?
See if u have any screws on the door(sides , top ,bottom or inside the door) if not with a little screw driver ( -- ) try to open the plastic juction to release it from the metal chasis
May 02, 2012 | GE Microwave Ovens
How to replace inner glass panel on Neff H7871 microwave
Hi Bill, I am having a same problem I have managed to order the glass from:-
http://www.4neff.co.uk/cgi-bin/product.pl?PID=876912&query=Neff%20H7871N1GB%2f01&model=H7871N1GB&path=127858
1. Open the door.
2. Take out the 2 screws just behind the handle, on the inside of the door, the door should flop down at the handle end.
3. Hold the door handle and pull the door out. It is only housed in by a slip in hooks at the bottom end.
4. Once you remove the door you will see the inner metal mesh and the inner door behind it.
5. Remove the 16 screws holding the inner glass with a special star type screw driver bit no T30.
6. Once you done that the glass housing holding the inner glass can be carefully prised free and taken off the inner door assembley.
7. Once you done that remove and inner glass, and be carefull to leave the glass glass seal intact, clean around the frame housing and the seal then replace the new inner glass and reverse the process.
PS. Becareful of the inner door once you've removed the outer door, as the hinges holding the inner door tend to shut quickly as there is less weight on the hinges.
It will do the job if you follow these instructions.Good Luck. AL
Oct 10, 2011 | Neff H7871 Convection/Microwave Oven
Own Whirlpool Microwave oven Model MH6141XKQ. How does one clean the "inside" glass of the door. By inside, I mean between the two glasses on the door.
You will need to remove the door and take the door apart to clean between the glass. This process is not that difficult. Just follow these steps:
1. Open the door all the way and lift straight up at the hinges to remove from oven.
2. Place the door, face down on a soft surface to protect the door and glass. A layer of towels on a countertop or table is recommended.
3. Remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel. Work your way slowly around the perimeter of the glass to release the clips that hold it in place so you can pry the plastic up and pop the panel loose. Use care not to pry against the glass.
4. With the inner panel removed, the glass should be easily accessible and can be carefully lifted out and cleaned. Clean with a good non-streaking glass cleaner.
Make sure you remember how the door is assembled as you take it apart. If you forget, the following webistes have illustrated parts listings to show how your door is assembled:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
If you have any questions, please post back and let me know. I hope this helps you.
Aug 12, 2010 | Whirlpool Microwave Ovens
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
I have rust like streaks inside my Whirlpool Microwave Door Panel. It is unsigthly. How do I get rid of the rust-like streaks?
Disassembling the door is a major pain and the streaks will likely only be faded not removed completely. Best solution is replace the door. Otherwise taking it apart(and not damaging it) is your only option.
Eric
May 19, 2010 | Whirlpool MH1140XM Microwave Oven
Handle came off at the bottom
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply tighten the screw(s) to the door handle and then re-insert the inner door panel. Carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Oct 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do I replace the door handle on my GE Spscemaker Microwave..I can only see one screw in the inside of the door. can't get to the bottom screw..
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
Aug 18, 2009 | Microwave Ovens
The handle on my maytag microwave oven broke off at the bottom. How do I replace ? Model MMV5165BA
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
Replacement parts can be found at any of the following sites:
repairclinic.com
Aug 12, 2009 | Maytag Appliances Over-the-Range Microwave...
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Aug 19, 2008 | LG MV-1444Y Microwave Oven
Microwave door has burn spots on the glass of the door...
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
Sharp R-820B Convection/Microwave Oven Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
