Question about HP 10b Calculator
My HP 10B calculator keeps calculating the wrong YTM.
Hello, I have an HP 10B financial calculator and I am having trouble calculating YTM. I enter the PMT, the N value, the PV (with a negative before it), and the FV, and keep getting the wrong YTM. What's going on?
  • 6 Answers
SOURCE: incorrect claculation
I get an answer of 366.91 in my 12C as well. You might try either putting in a zero for FV before hitting the [PMT] key, or clearing your registers before doing the problem, as you may be picking up an old value from a previous problem in the FV register.
Posted on Jan 30, 2008
SOURCE: invalid computation
Hmmm, I don't think the problem is with your calculator. I'd be checking the accounting question again as I don't think you've got your annuity question structured right.
4 Year Annuity
14% Annual Interest Rate
Your contributing $4,000 per year over the next 4 years
and you already know the future value is $50,069?
You'd have to make annual payments of $11,878.93 (4 of them) at that annual interest rate to get to a future value of $50,069 (which has a present value of $43,632.24).
Are you sure that the FV isn't the trade in value at the end of the 4 years?
Posted on Mar 30, 2008
SOURCE: Computing N in a TVM calculation (receive Error 5 message)
Hey,
Just found out the answer!
Apparently you can't have both FV and PV positive. Try the calculation with one of them being negative.
Posted on Jan 19, 2009
fatherofsun
  • 38 Answers
SOURCE: the calculator is giving me
Resetting the calculator using the keyboard To completely reset the calculator and erase all user memory, follow the procedure below.
  1. Press and hold [C]. Press and hold the first key from the left ([N]) and the first key from the right ([FV]) on the top row.
  2. Release all three keys at the same time.
  3. The calculator will go blank, and then display "CORP HP 2000."
  4. The message will disappear and the calculator will display "ALL CLEAR."
  5. Press the [ON] key to clear the message.
Resetting the calculator using a paperclip To halt the calculator and reset the keyboard, follow the procedure below.
  1. Turn the calculator over and remove the battery door.
  2. Insert a paperclip into the small round hole located between the batteries. Insert the paperclip as far as it will go.
  3. Hold for one second then remove the clip.
  4. Press the [ON] key.
  5. If the calculator is still not responding, try one of the other methods
The batteries must be removed for at least 24 hours to drain the capacitor completely
Please comments back that your problem solve or not so may i further help u..
Posted on Aug 18, 2010
  • 102366 Answers
SOURCE: My BAII isnt calculating correctly
Change the payments-per-year to 1 to get the correct answer. Press 2nd [P/Y] 1 ENTER.
To pay off a loan of $3245 at 12% annual interest, you can either make 6 monthly payments of $559.91 and pay it off in half a year or make 6 annual payments of $789.27 and pay it off in six years.
Posted on Nov 26, 2010
Display is faint and to light to read
Turn the calculator on. Hold down the "C" key (just above the ON key) and press + to darken the screen. If you go too far, use the C and - keys to lighten the screen.
Jan 21, 2012 | HP 10b Calculator
How to clear RAD on the display of the HP 10b ?
For what purpose? If you are not doing trigonometric calculations it will not matter. It merely reminds you that the angle unit (for trigonometry calculations) is set to RADians.
If you need to change the angle unit to degree or grad do so. The new unit will replace RAD.
Jul 12, 2011 | HP 10b Calculator
I wonder what is the model of the battery using on HP 10b
HP 10b Calculator requires two CR2032 Lithium batteries. The battery is 3 Volts, 3/4" in diameter and has an estimated life of three years. Replace the battery with CR2032 or an equivalent one.The following brands are used interchangeably for this item: Energizer (ECR2032), Duracell, Panasonic, Eveready, and 3M etc, which can be purchased from any local electronics store.
For further information you may refe to HP 10b Manual
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Feb 27, 2011 | HP 10b Calculator
Setting number of decimal places on a HP 10B business calculator
Press SHIFT [DISP] and the number of decimal digits you want.
Dec 14, 2010 | HP 10b Calculator
Replace the batteries of HP 10B calculator
Make sure the calculator is turned off. Press down and outward on the battery compartment cover until it slides off. Turn the calculator over and shake the batteries out. Insert the new batteries, orienting them according to the diagram inside. Slide the cover back into the slot.
Oct 21, 2010 | HP 10b Calculator
Hi, I have an HP12C and for some reason the
Turn the calculator off. Hold down the period (decimal) key and hit the "ON" button at the same time.
Mar 03, 2010 | HP 12c Calculator
I have a comma where the decimal should be. How do I exchange?
Hello
To switch between the two, press the [SHIFT] then press the key in the middle of the bottom row (the key you use to enter a decimal point).
[SHIFT][./,]
Hope it helps.
Oct 09, 2009 | HP 10b Calculator
How can i tell the difference b/w hp12c and hp12p. i bought a hp12p from ebay(it's a stupid decision, I know!) and when i solving for IRR, i felt its running quite slow. I think the guy sold me the hp12P...
I couldn't find any reference to a HP calculator model 12p.
There is a HP 12c financial calculator and a 12c Platinum financial calculator.
Check both models (for images, specifications, functions, user guides, etc.) :
HP 12c Financial Calculator
HP 12c Platinum Financial Calculator
Aug 06, 2009 | HP 12c Calculator
RAD
Change the angular mode to something other than radians.
May 18, 2009 | HP 10b Calculator
STuck on screen
take the battery out and put back again it will reset the whole calculator
Jan 15, 2009 | HP 10bII Calculator
HP 10b Calculator Logo
452 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
