Question about Dell OptiPlex GX270 PC Desktop
Dell Optiplex gx270
How do I change the processor speed? I switched out the P4 @ 2.26 ghz processor for a P:4 2.8ghz. The bios says speed is 1.6ghz. Windows XP pro shows 2.8 and 1.6. I updated the bios to A07 and the Intel chipset from Dell's website. Still not able to change the speed.
  • 490 Answers
Hi, reset the BIOS u need to follow below given steps(Perform all the steps carefully )
1.Restart the notebook.
2.Tap the F10 key as soon as the Dell logo appears.
3.Using the arrow keys, navigate to Exit Menu, select "Load Setup Defaults" and select "Exit Saving Changes".
Posted on Oct 15, 2007
Optiplex replace power supply
Hello Jacey,
Below are the system specs for the power supplies that are installed in each chassis of the GX280 system. You can call the Dell Spare Parts
Department at 1-877-717-3355 or click the link below.
Spare Parts Department
Wattage small form-factor computer: 160 W
small desktop computer: 210 W
small mini-tower computer with processor speeds of 3.2 GHz or lower: 250 W
small mini-tower computer with processor speeds of 3.4 GHz or higher: 305 W Heat dissipation small form-factor computer: 546 BTU/hr
small desktop computer: 717 BTU/hr
small mini-tower computer with processor speeds of 3.2 GHz or lower: 853 BTU/hr
small mini-tower computer with processor speeds of 3.4 GHz or higher: 1041 BTU/hr Voltage fixed-voltage power supply-110 V at 50/60 Hz manual selection and auto-sensing power supplies-90 to 135 V at 50/60 Hz; 180 to 265 V at 50/60 Hz; 100 V at 50/60 Hz for Japanese computers
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 23, 2013 | Dell OptiPlex GX280 PC Desktop
Upgrade processor, unknown socket type.
Here I have found the technical specifications for this system, but for informational purposes it is pentium 4 and celeron 478pin intel only.
Oct 30, 2009 | Dell OptiPlex GX270 Small Mini-Tower...
I have a Dell Optiplex GX270 running on windows XP pro. It has 2MB RAM and 80GB hard disc drive. When I checked to see if I could run Windows Vista Ultimate, the checker said I could, but might need to...
You'll need to have at least the following specs to run vista comfortable; 1 or 2 Ghz processor 1 or 2 GB RAM Video : AGP with 256mb or more cache Yoy might also have to consider changing your power supply.
Aug 13, 2009 | Dell Optiplex GX270
Dell Optiplex GX400 w/ 6F067 main board. What is largest processor can this handle? Currently P-4 1.3Ghz.
According to the motherboard's specs for the Dell Optiplex GX400, it's chipset is Intel 850. This chipset will support 1.7 GHz processor. Not sure whether it could support higher speed processors or not.
Jul 07, 2009 | Dell (6F067) Motherboard
My Pentium 4 2.4 GHz processor is running at only 1.9 GHz. The bus, supposed to be running at 800MHz, is running at 398. The motherboard is Dell Optiplex GX260. Can someone please help me speed up my...
in the BIOS-setup, normally you can adapt the bus speed. as it's running at about 400mhz, i suppose it's set to auto. within the advanced system settings, you should be able to set the bus config to manual and then you can choose the appropriate bus speed below.
Jun 22, 2009 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
OptiPlex GX270 can be small form-factor, small desktop or small mini-tower. The DIMM slots and therefore maximum memroy capacity depends on the form factor. Double check our OptiPlex GX270 and find memory info below.
Memory Type
333MHz (PC2700) or 400MHz (PC3200) DDR SDRAM
Memory connectors/DIMM Slots
small form-factor: 2
small desktop: 4
small mini-tower: 4
Memory capacities Supported
128MB, 256MB, 512MB, or 1GB non-ECC
Minimum memory
128 MB
Maximum memory
small form-factor: 2 GB
small desktop: 4 GB
small mini-tower: 4 GB
Apr 13, 2008 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX270 PC Desktop Logo
2,508 people viewed this question
Alun Cox
