Question about Kenmore Washing Machines
Drain pipe overflows from washer
We have determined that the Washer is actually causing the drain to overflow. This problem is new as the washer 6 yrs old.
  • Anonymous Mar 18, 2014
    washer overflows when draining
    President:
  • 2,992 Answers
Something is blocking the drain and it can't keep up with the flow now. You can try cleaning the drain with an auger (available for not much money at home supply stores). You'll probably find a sock or lots of lint built up.
Posted on May 13, 2009
Washer overflow from drain pipe
If the water continues when electricity is discontinued the soleoid valve is jammed open, a fleck of rust or something, not designed to be repaired, it is easier and cheaper to replace. they are a standard part that fits 99% of all washers ~$10-20 at the local parts guy.
Usually only the cold solenoid has failed. it gets used more often.
If you are like me and only use cold water, swap the hoses on the taps, and swap the wire connectors on the solenoid valves, so the former hot is now cold, and you will get about the same number of years before you have to replace anything
Nov 27, 2012 | Maytag Washing Machines
I just purchased an LG Front Load washer (Model WM2140CW). Best buy installed it. When I went to use it today, the floor flooded. Water was gushing out of the drain pipe (backing up). The LG drain hose...
You may have a drain line restriction causing it to back up. Pull the drain hose up about 6 inches and try it again. If it does overflow again, you will need to call a plumber to clear the drain line out in your plumbing.
Jun 16, 2011 | LG WM2140CW Washer
Can a brand new top load whirlpool washer model wtw1500vq2 overflow or does ithave automatic shut off?
DEPEND WERE IS THE OVERFLOW IF ITS ON THE DRAIN HOSE ATTACHED ON THE WALL U MAY CHECK THE DRAIN PIPE CAN BE CLOGGED. ANOTHER THING ITS THE WASHER HAVE A WATER LEVER PRESSURE SWITCH PROBABLY BE DAMAGE.
Nov 11, 2010 | Whirlpool Washing Machines
Washer empties faster than pipes allow causing overflow
More then likely you have a partial clogged drain also, New washer output is alot faster, Being a plumber its not getting enough air to let it drain properly. Check drain for clog and vent is wrking properly
Mar 01, 2010 | Washing Machines
My washer drain pipe is overflowing on my floor
Sounds like your drain pipe is restricted or clogged. Try using a "Pipe Snake" to unclog.
Jul 26, 2009 | Kenmore 500 6953 Dryer
Kenmore washer leaking during rinse cycle
Your air vent in your drain line is stopped up in your plumbing. Your washer is fine.
Jul 16, 2009 | Whirlpool WTW6400SW Top Load Washer
Drain pipe for washer overflows..how do I clear it out?
if the water is coming up from the drain it means your drain is restricted you either need a plumber or you have to run a plumbers snake down the drain to clean it outl.
May 30, 2009 | LG WM0001HTMA Front Load Washer
Water overflows from drain pipe
2 ins is rather small and there may also be a partial blockage somewhere in the system you are not aware off.
a naughty cure is to restrict the drain hose of the machine so water comes out a bit slower
Sep 05, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
97 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
