Question about Akai PT4298HD Rear Projection Television
Lines running through tv akai pt4298hd
Lines come and go on screen sometimes works fine other time has lines on it already cleaned mirror and lamp lens some channels are fine other have lines also tried different inputs but same problem lines am running component for dvd player
  • philipsmecha May 13, 2009
    lines go on angle and are dark with some waves on a dark backgound there is a light red line almost purple
    about 4 inches wide in almost the middle of screen
  • geod794 May 19, 2009
    akai pt4299hd has lot of red in screen and red lines thru it
snakehead
  • 1074 Answers
SOURCE: NO Picture in Color except for PIP
have a tech check your tv the color circuit needs to be looked upon.good luck
Posted on May 07, 2007
SOURCE: Actually...it's a Akai PT5299HD
I HAVE A AKAI PT5299HD TV AND WHEN I PUT ON THE AUTO FOCUS THE TV KEEPS TRYING TO FOCUS ENDLESSLY BUT DOES'NT FOCUS. IS THERE A WAY TO MANUALLY FOCUS THIS TV-MY WRITING ON THE SCREEN IS BLURRY?
Posted on Jan 11, 2008
  • 20 Answers
SOURCE: AKAI PT4298HD
Do not panic! Do not throw your TV away like I wanted to! Here is what may be the solution for most of the members who have posted their complaints here recently. I am not an expert, but I followed all blogs from various websites and forums, and the conclusion was the same; replace the convergence board for this model. I purchased it from www.partstore.com and since this Akai is the same model as the Samsung Model # HCN4226WX/XAA, buy the Samsung BP95-00142E Convergence board for $77. It came to about $85 after shipping. The Convergence board has two black STK ICs and two colors of wires, a gray kind and a blue kind, all which have 'pins' and can easily be unplugged from the circuit board in the TV. It is basically a complete system that takes less than 30 minutes to install. It is a simple swap procedure, with no soldering. You only need the new board and a screwdriver! Remove the lower back board of your TV where the cables are plugged in (do not unscrew all the screws for the screen, as it is unnecessary, and might just damage your screen if you are not careful.) It has a u-like shape and comes off easy. Detach the gray wires connecting your old board to the rest of the circuitry, and detach the blue wires connecting the old board to the circuitry. On the old board, there are connectors marked, from left, blue, green and red. Detach those from the old board, and mark the wires so that you may connect the correct the wires to the new board. You then unscrew the only screw connecting the board to the TV, and unhook the board from the TV. Hook the new board to the hooks which held the old board, and screw the lone screw to the board. Plug the gray cables from the new board to the connectors where the gray cables from the old board were,and do so for the blue cables. Connect the multicolored cables to the blue, green and red, just as was done on the old board. Reattach the cover and test the TV. Please do not replace the two STK ICs only. When I removed my old board, I realized that there was a burn mark, where the ICs were, but maybe it was a fuse. You may replace the ICs only to discover that it was another problem. Good luck, and I wish you all the best in the repairs. I just saved about $100 for a repairman just to show up
Posted on Dec 11, 2008
SOURCE: Akai PT4298HD Rear Projection Television Problem
My AKAI 42 rear projection self focus set has blue shadows on everything and too much red, I cant seem to adjust it and self focus does not help?
Posted on Mar 23, 2009
SOURCE: AKAI - PT50DL14X\SMS DLP TV
lamp reset code
Posted on Feb 10, 2011
Where is the TV fuse located
Hello!
If you haven't replaced the lamp before, it's better if you do, if you already replaced it and this issues are still there, it's a possibility that your ballast might be defective, maybe it doesn't have enough voltage to light up the lamp
Jul 08, 2009 | Akai PT4298HD Rear Projection Television
2006 Akai 23" Led TV says it gets no signal.
hi, the input blocks are where you will need to look for this problem. sometimes these block connection become lose and detached from the main logic board. this could happen due to a minor crack in the solder or to much pressure when inserting cables and input rac jacks etc.. replacing or repairing this section of your TV's board will fix this issue.
Feb 25, 2009 | Akai PT4298HD Rear Projection Television
Vertical line on rear projection TV - Akai PT4298HD
this is an indication of a burnt crt. unfortunatly to fix this the crt will need to be replaced. such a repair is something i would recomend to a non tech. theres adjustment issues
Oct 30, 2008 | Akai PT4298HD Rear Projection Television
PT4298HD Power does not work
The power button is not working, the light will flash however, nothing appears on screen
Oct 29, 2008 | Akai PT4298HD Rear Projection Television
Akai PT42198HDX/SMS
Set could just be way out of adjustment or there is problem with video circuit
Jan 16, 2008 | Akai PT4298HD Rear Projection Television
Akai tv
have a good tv guy repace you convergence amp's john
Jul 31, 2007 | Akai PT4298HD Rear Projection Television
Faint diagonal lines in t.v.
try turning down screen controls. turn up until you see the lines and then back off until they dissappear...easy as that! john
Nov 29, 2006 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
165 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
