Question about Pioneer DEH-P4000UB CD Player
When i turn on my pioneer sterio in my dodge intrepid my brake lights and illumination lights will not come on
  • richards_pho May 16, 2009
    thanks i understand that much!!
  • 150 Answers
It is wired up incorrectly
Posted on May 13, 2009
Horn and brake lights
This happend when you put a new sterio? Now your horn and tail lights dont work. Well some models require and extra harness to make the after market sterio work, check in to that. Or a fuse, make you where the wire is and trace it to see if it goes to the radio
Feb 27, 2013 | 1993 Geo Tracker
Which fuse controls the passenger side brake light
Any fuses that have to do with brake light. You usually can find them all in your owner's manual.
Oct 26, 2011 | 2002 Dodge Intrepid
Brake lights will not go off in dodge intrepid
It seems like you may have a bad Brake Light Switch, which is located on your Brake Pedal. The switch is activated when you step on the brakes it sends a signal to the Brake Lights to turn the lights on when the pedal is depressed, if it is defective it may be keeping the Brake Lights on. You can purchase on and replace it yourself, it is not very difficult.
Jun 03, 2010 | 2000 Dodge Intrepid
My 2000 Dodge Intrepid is turned off but the brake lights remain on.
sounds like a bad brake switch...should just be connected to the brake pedal under the dash...crawl under there and see a white box, with a plunger hanging out of it resting against the brake pedal...unbolt/remove it, unplug it, and replace it...you cannot rebuild one of these, nor can you reinstall an old one after removing it for any reason..
Nov 18, 2009 | 1999 Dodge Intrepid
Where is the Hazard/Turn Signal switch located in a 2000 Dodge Intrepid? My Turn Signals & Hazards stopped working without any warning and all light bulbs and fuses appear to be good. I have ordered a...
2000 Dodge Intrepid 2.7L SFI DOHC 6cyl
The Flasher is located front seating area, driver side, under left hand side of instrument panel between junction block and brake pedal.
Oct 30, 2009 | 2000 Dodge Intrepid
Need a wiring diagram for brake lights on a 1995 dodge intrepid ,the two main lights are inop,the center light is ok
Check for 2 brake light switches on the brake pedal some vehicles run different switches for the 2 lights. look for power in to both and out of both when you press the pedal.
Oct 24, 2009 | 1995 Dodge Intrepid
The indicator light that give miliage/temp/ will not come on. 2002 dodge intrepid
Are you trying to say that the light that illuminates the temp gauage and the speedometer gauge don't come on? If so you need to replace the bulbs from behind the instrument cluster. If help needed reply on this post.
Mar 25, 2009 | 2002 Dodge Intrepid
I have a 1997 dodge intrepid my brake lights are not working but the tail lights are so which bulb is the brake light , the one one on right or left.
first of all do you have a third brake light and does it work???? you could have a bad brake light switch turn on the head lights check all rear lamps then put on the 4 way flashers and check the bulbs the ones that dont light should be the brake lights or replace the tail lights they should be double fillament
Jan 29, 2009 | 1997 Dodge Intrepid
1997 Dodge Intrepid rear brake lights
check the switch by the brake pedal. This is what turns on the brake lights.
Jun 28, 2008 | 1997 Dodge Intrepid
2000 Intrepid turns over no spark
"No Bus" usually means you have a bad ground. Check the condition of the battery ground, clean it if necessary. Check other grounds as well.
Jun 10, 2008 | 2000 Dodge Intrepid
Pioneer DEH-P4000UB CD Player Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
