Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Flaky Headphone Jack
My player seems to work fine but I can't hear anything. If I jiggle the plug while in the jack, I get intermittent connection for one ear. The solder joint is under the LCD panel and I'm hesitant to start messing with that. Any suggestions?
Unfortunately the Zen Xtra was designed poorly and this problem tends to happen sometime along the life of the product.  As you suspected, the problem is the solder joint and the only solution is to open the player and resolder it yourself.  As long as you are careful, you shouldn't have any problems.  The hardest part is trying to get the thing back together after you took it apart:  Just be sure not to loose any of the pieces.  Detailed instructions with photos are located here:
http://www.pcpages.com/thebishop/nomadfix/
Posted on Oct 15, 2007
SOURCE:
Suddenly there is no sound in the speaker but headphone works fine..laptop is Lenovo B575
If the head phone jack works its more likely to be the problem, if you use the headphone jack a lot the connections inside it can get worn or bent out of shape--engaging the headphone jack should shut the speakers in the unit off.
Other possible reason is a bad speaker or connections.
Dec 14, 2012 | Lenovo B575-1450A5U - IdeaPad Laptop / AMD...
Audio jack seems to have short
There is probably a broken solder where the audio jack connects to the mainboard. If you are in warranty, then contact HP and they will fix it free of charge. If not, then pick up a usb sound card. They are cheap ($20), plug into a usb port, and have a speaker and headphone jack. This will fix it.
Regards,
Joe
Apr 07, 2012 | HP Compaq 6510B 14.1" Laptop
Sansa clip headphone jack -- headphones work fine on other players or phone, but clip plays only one ear. If i jiggle the headphones thingie inside of jack i get sound in both ears sometimes. 1) Any...
the jack inside the unit either is bad or the solder connections are bad...you can re-solder the jack(if you know how to solder) and see if this fixes it...or else you'll have to replace the jack(which may be avail. through Radio Shack)
Jan 14, 2011 | SanDisk Sansa Clip MP3 Player
Headphone jack
You must have not plugged in it properly, force the jack till the end of the socket so it locks in with a click, then it will work fine.
Jun 07, 2010 | Audio Players & Recorders
Why do I only hear half the sound?
well it could be a simple a) plug headphones in more/less in the jack or b) the jack left/right side of the jack needs resoldered on the board inside where the guts of the hardware is.
Mar 14, 2010 | Nextar MA933A MP3 Player
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Loose headphone connection on mp3
Replacing a headphone jack on a Sansa is a risky endeavor that is bound to do further damage to your player - the original jacks are not orderable directly from Sandisk. Your best bet is to call Sandisk and get an in-warranty replacement.
-Tha Mp3 Doctor
Mar 11, 2009 | SanDisk Sansa e260 MP3 Player
Ear phone jack
what a coincidence.  had the exact same problem today.  ur connection on the inside of the player between the circuit board and the headphone jack is probably broken.  I had to re-sauter mine.  just open it up and take a look
Oct 21, 2007 | SanDisk Sansa e250 MP3 Player
Cannot hear music
The bad news is that your headphone jack is most likely shot. The soldered connections inside are most likely broken. This is not repairable generally, at least not for a cost that would be reasonable. Music will play through your computer because it can be read off your player through the USB connection. Use it as a data storage drive and buy a new one, or a used one. I've seen used T30s on Amazon for around $30 to $40.
Mar 26, 2007 | iRiver T30 MP3 Player
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
96 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
