Question about Poulan 12a Elec Blower/Vacuum
How do you relace the recoil spring in poulan weed eater lt1500le
  • dan_montecar May 14, 2009
    Thank You, your solution seems easy enough.
  • 246 Answers
Hello dan_montecar:
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
This is a Basic File and your Unit May be Slightly Different.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP&lang=EN&TF=Mainframe&LoginID=hywd&loginpwd=hywd&Partner=HYWD and Select the Catalog Poulan/Weed Eater.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
  • John C Bridgers Sr May 14, 2009
    Hello Again dan_montecar:
    You are Very Welcome.
    >>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
    Best Wishes and Good Luck
    Respectfully
    jbridger (John)
Repair weed eater
just apply some oil to the mech.
Jun 05, 2013 | Poulan Garden
Weed eater featherlight XT260 rope pully
Your recoil could be messed up if you cant pull the rope out or if its just too hard to pull out you could have it too tight.
Jul 29, 2012 | Poulan/Weed Eater No. Te475 952711797 17"...
After pulling the starter coil, it will not be pulled back into the machine or better said, it will not coil for another attempt at starting.
Sounds as either the recoil spring located under the the recoil housing has either broken or the plastic housing that holds the spring end has broken. you will need to remove the recoil housing to determine the problem. To remove:
1. Remove the drive tube by removing the clamp around the front of the housing and gently pull the drive tube from the engine.
2. Remove the torx or slotted screws holding the recoil assembly on
3. Remove the star washer with a flat screwdriver and gently lift the recoil from the housing.
The spring will be directly. You should be able to see the problem at that point.
Sep 27, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Replaced starter spring on Poulan/weed eater FL1500LE leaf blowe.
you may have wound the spring backwards, try winding the othe way.
May 09, 2010 | Garden
Cant remember how to put the spring back on the pull cord recoil
This reply is based on the following assumptions:
A Poulan PP2375LE (wildthing) Type 2
The starter recoil spring is unwound.
All components aer servicable
Poulan 2375LE Type 2 IPL
http://www.ordertree.com/modelinfo/PWE/2375LE-Gas-Saw-Type-2/75.2375LE-Gas-Saw-Type-2.1.59.1.html
Starter components and reassembly order are illustrated on the "Handle, Chassis & Bar Assembly" detail.
If the spring needs rewound this is how I do it, there are other methods.
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, and both hands). I am right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool.
This illustrates proper pretension and rope installation:
Smalleng.com (about 3.5 minutes long and worth watching the entire video)
http://www.youtube.com/watch?v=eRyy3MlsjVo
If yours is not a Type 2 you can find the correct IPL here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
I hope this was helpful
Lou
Jan 29, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil assy won't fit against motor.
suggest as you try to align the pulley to the engine, that you pull the recoil rope a small amount. Many times this will align the mechanisms and allow further installation.
Nov 10, 2009 | Poulan Garden
Rewind a recoil starter spring. I've spent many hours trying to get the recoil spring put back in its place with no luck.
I DID THIS SAME JOB BY WINDING THE SPRING UP IN MY HAND AND THEN TOOK 2 TWIST TIES AND WRAPPED THEM AROUND THE SPRING TO KEEP IT IN THAT CONDITION. I THEN INSTALLED THE SPRING WITH THE LONG END OF THE TWIST TIE EXPOSED AND AFTER GETTING THE ROPE HOUSING IN PLACE I PULLED THE TEWIST TIES OFF WITH SOME NEEDLE NOSE PLIERS. HOPE THIS HELPS
Sep 25, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan model p 3314 33cc chainsaw recoil jams up, I have taken it apart, and the pulley seems to be side loaded the screw that holds the pulley is crooked.
I recommend you contact Poulan 1-877-500-7499, there may be a free replacement kit available. If you call please have your saw at your side before dialing.
An IPL for your saw can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html (P3314 Gas Saw)
There are 2 different types "Spring Assist Pulley System" and "Standard Pulley System". Exercise care when you order. HTH
Lou
Please leave some comments about what you found to help me help those that follow you..
Sep 23, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Poulan 12a Elec Blower/Vacuum Logo
943 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
