Question about Microsoft Excel for PC
How to create frequency distribution using exel
  • Microsoft Master
  • 4,806 Answers
Hi there.
Its too much information to type here but check out this link for a full walk through >>>>>>>
http://www.cob.sjsu.edu/anaya_j/FreqDist.htm
Good luck and thanks for using FixYa!!
Posted on May 13, 2009
How is the electricity distributed in Singapore?
In Singapore, the one who is in charge to distribute the electricity through nation is Singapore Power Services (SP Services). The company provides electricity andgastransmission, distribution services, and market support services to more than a million customers in Singapore. It is one of the largest corporations in Singapore. Singapore Power was first incorporated as a commercial entity in October 1995 as Singapore Power and Gas, but because the abbreviation of that name (SPG) had negative connotations, it was quickly changed to Singapore Power, it was created to take over the electricity and gas businesses of the state provider, thePublic Utilities Board. Since 1995,Temasek Holdingscontrols the entire company with a 100% stake. https://iswitch.com.sg/how-to-iswitch
Apr 17, 2017 | Electrical Supplies
I have a Precor 9.45 I that states error 10 what is wrong with it
Precor Error 10, Line Frequency out of Acceptable Range Probable Cause 1. Treadmill is connected to a non-dedicated AC circuit
2. The AC hot and AC neutral wires are reversed on a 120VAC circuit.
3. The upper PCA has an incorrect jumper setting.
4. Fuse feeding the stepdown transformer is bad.
5. AC line frequency is incorrect.
6. AC line may be excessively noisy. Corrective Action
  1. Treadmill must be connected to a completely dedicated 20amp AC circuit. Both hot and neutral leads must be dedicated to the treadmill. If the circuit is shared with another piece of equipment, it can cause enough electrical noise to make the AC line frequency impossible to identify. The AC circuit for the treadmill must be re-configured as a completely dedicated 20amp circuit.
  2. Many line frequency detection systems observe the AC line frequency on the hot AC line. In the event of a reversed 120VAC circuit, the observation is taking place on the neutral (ground) part of the AC line. Many observing systems are not capable of detecting line frequency on the neutral line. First it must be determined if the reversal is in the AC wiring feeding the treadmill or in the internal wiring of the treadmill. The hot and neutral lines can be confirmed by measuring each in reference to AC (green wire) ground. The hot wire will read full line voltage (commonly 105 - 120VAC) and the neutral should read about 0VAC.
  3. The upper PCA's for some units had a jumper setting for use with SCR or PWM drive circuits. If the jumper was set on the upper PCA as PWM on an SCR unit, the Error 10 appears. Change the jumper setting to SCR to correct the problem.
  4. A pair of fuses were used on some treadmills (C944 PWM version 2 and C96x PWM version 2) that fed the stepdown transformer for the low voltage power supply on the lower PCA. The AC line frequency was observed on the output of one of the fuses. If the fuse blew, AC line frequency could not be detected even though the treadmill appeared normal under other circumstances.
  5. It is unlikely, however, the AC line frequency could be out of acceptable limits. This would more likely occor in countries were AC power systems may not be well developed and controlled. There is little that can be done to correct this issue. If the source frequency cannot be corrected, the only possibility would be replacing the treadmill with one that utilizes a PWM motor controller. PWM motor controllers do not depend on line frequency for speed control.
  6. At times the AC being fed into the distribution system is too electrically noisy to allow correct line frequency identification. This can be caused by other equipment within the AC distribution system creating the electrical noise. It can be difficult to identify the source of the electrical noise. There is little that can be done to correct this issue. The source needs to be located and removed or made electrically quiet. If this cannot be done, the only possibility would be replacing the treadmill with one that utilizes a PWM motor controller. PWM motor controllers do not depend on line frequency for speed control.
Precor Error Code 10 10 Line Frequency out of Acceptable Range
Jun 11, 2014 | Precor 9.1 Mode 1 Treadmill Repair Parts...
Construct both an ungrouped and a grouped frequency distribution for the data given below: 139 130 128 134 140 139 136 130 136 128 138 137 134 128 127 136 140 132 141
Sorry to disappoint you but I will just give you directions to do it yourself.
Ungrouped
First sort the data in ascending order (from lowest to highest value)
Create a two-column table
In the first column enter a data value.
In the second column enter the frequency of a data item
Count how many times one particular data value appears in the set (how many repetitions). If it appears only once, its frequency is 1; twice, frequency 2, etc.
For each single (different) data value complete the frequency column.
Grouped
For grouped data representations you create classes: A class is just an interval of values, for example between [125, 130[
For each class interval you create, count how many data values fall within the interval. For the class given as example it will encompass all values between 125 and 129, It I counted correctly its frequency is 4.
Complete the frequency table for the class.
How many classes should you create? Usually this information is given to you. If not, create a moderate number of classes (4,5) It depends on the span of the distribution (highest value- lowest value). The intervals should have equal length. Read your instructions.
Sep 02, 2012 | Office Equipment & Supplies
Exel 2007 not open in exel 2003
This is because 2007 excel uses a different type of file. You may follow the directions at the link below on how to save files in 2007 excel so that you can open it in 2003
http://office.microsoft.com/en-us/excel/HA100141071033.aspx
Sep 25, 2008 | Microsoft Office Professional 2007 Full...
EXEL 2007
If there is anything else please do message me.
Create a software
there is a process but I can't remeber its correct name,
First thing is to identify a specific needs (software related)Research & Development ie platform/s
The frequency of demands
the execution
the results(outcome)
the developer will be the key to making this work,
so consult as much as you can,
research the lot as much as pos
when the ideas a sound model then manufacturing and distribution
Big time testing is required before the release to the public
Lots to do now,,,,Let me know if theres anymore I can help with
Aug 08, 2008 | HP Pavilion dv6000z Notebook
Labeling from exel
If you follow the Mail Merge instructions built into Microsoft Word's Mail Merge Wizard, you can use your Excel file as the data source for your Mail Merge document, which can be created using label templates built into Word or downloaded from the label manufacturer's website. If you need more detailed instructions, please let us know what version of Microsoft Office you're using, as well as the Operating System (PC or Mac, Windows '98, XP, Vista, Leopard, etc.) and the label manufacturer and label name and product number. Please let us know if you need more help.
Dec 11, 2007 | Computers & Internet
No distribution list on a nokia 6230i
I researched on your phone's specifications and found out that it is indeed of sending messages to your distribution list. I am not so familiar with this model, but based on a lot of Nokia phones I have used, you just have to go to your messaging options. The option to create a distribution list is there.
Jan 28, 2007 | Nokia 6230
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
171 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
