Question about Sharp AL-1641CS Laser Digital Copier
My copies come out very dark, I replace tone and drum and still have the same problem. Please, help
  • 3 Answers
Go to ara that has serveral setting for print set. or change the font it might be on a thick dark setting.
Posted on May 13, 2009
Poor copy quality
The drum, developer and other parts have a certain life that they are good for. After they go beyond that cycle they can start to run dirty, use alot more toner, basically give you problems until a complete maintenance is done. The drum can have permanent light fatigue, even though they look good and in alot of cases one side will start to get darker than the other. You should get an estimate of what it'll cost to have servicing done and compare that with the cost of a new or refurbed machine. If the copier is very old, it might be worth it to get a new one. Good luck, please rate this if it helped you. Thanks
Jul 02, 2009 | Xerox Office Equipment & Supplies
DARK SPOTS
Are the dark spots random and moves location with every copy or are they at exacly the same place on every copy? Random you will need to remove the drum/toner and use a blower to clean the inside of the machine,failing that replace the drum unit.If the spots don't move clean the top glass.Let me know
May 21, 2009 | Sharp AL-1641CS Laser Digital Copier
Our Gestetner DSm645 gives Dark Copies..........
Sounds to me like the drum needs replacing, and likely the developer too. There is probably a haze of toner still on the drum. You can check by opening the right side cover and looking at it. Is there toner on the drum (green cylinder). It may not be too obvious depending on how dark the copies are. GENTLY wipe a tissue across it after making several copies - it should be clean if the drum is functioning properly. If it is, it could be the fuser that is wearing out, but I'm leaning toward the drum. As I said, if you need to replace this, it is a good idea to do developer at the same time, because these machines tend to be a little sensitive.
Mar 18, 2009 | Office Equipment & Supplies
SHARP COPIER
Have you cleaned the optic's? what roller was replaced? Was it the drum unit? If not you may need to replace the drum unit.
Jan 22, 2009 | Sharp SF 2020 Copier
PRINTING IS DARK
Dark copies (whole pages) are usually a result of poor charge of the drum. Drum is that green thing (usually, seen blue ones too). You get text and graphics in places, where the drum has been discharged (light discharges drum). So if everything is dark - the drum is discharged fully, or not charged at all. Look for bent, dirty or missing connector plates, springs, paper covering contacts. If you get lines it could also be the fuser (hot thing) - needs replacing. Everything depends on how the copy looks like, I would have to see it. Hope this is helpful somehow ;-)
Aug 28, 2008 | Brother HL 5140 Laser Printer
Dc1q2
What is sounds like to me, it you need to replace the developer.
Once it is in the machine for an extended period of time, the ink no longer transfers onto the drum properly and your copies become washed out.
It is rather amazing the differenece a fresh shot of developer will make.
Mar 26, 2008 | Xerox DocuColor 12 Color Copier
AR 5316 VERY DARK BLACK COPIES
You need to check the drum unit for wear or the main charge assembly. If you are not mechanically inclined, just replace the drum unit and clean the transfer charge on the right side door.
Don't forget to rate your answers please.
Jan 26, 2008 | Sharp AR-5316 Advanced Digital Imager...
Canon 330s Copier with Dark printouts
How dark is it??
canon is sensitive to dust,
turn off machicne take off top copy glass move scanning glass and wipe with a clean towel.
try adjusting the dark and light does it change? if it comes out better on light then the drum is the problem. ( getting old)
Nov 29, 2007 | Canon imageRUNNER 400S Copier
Prints dark black instead of grey tones
your drum is going bad. or your light or dark adjustment is set too dark ( it should be in the somewhat in the middle).
change drum
Nov 06, 2007 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL-1641CS Laser Digital Copier Logo
79 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
