Question about Faber Perla 602599 Kitchen Hood
Problem changing halogen bulbs on perla rangehood
I have a faber perla canopy rangehood. Naturally both halogen lights went out at the same time. In trying to remove them, the panel will not slide as the manual directs so I can't remove the panel, nor the bulbs :-(
Anyone have an idea to "ubnstick" the sliding panel?
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
Posted on May 14, 2009
Are halogen bulbs a good form of light source to use for lighting a reptile's habitat?
As for the positives, halogen bulbs last a long time, are very energy efficient and produce a lot of visible light. On the downside, this type of bulb does not emit UVB light. The link below will lead you to a good quality halogen bulb, where you can find more information.
http://www.drsfostersmith.com/product/prod_display.cfm?pcatid=18316
Sep 04, 2012 | Aqueon Reptile
I need to find out the light bulbs relacements for a zephyr rangehood, model venezia
Check out the zephyr Site. The halogen bulbs they use are very unique. Have two clients that have Zephyr hoods and took me a while to locate replacement bulbs. Could not find them at the local lighting stores nor hardware stores. I believe it is a 35 watt halogen (sort of an MR-16 size) with an entended base.
Oct 19, 2010 | Kobe Rangehoods CH-100 Series - 36" Wide x...
Can I put a 35 watt bulb into a Rangehood?
Yes it will possibly just be a little brighter... but should do no harm. The original 2 would equal 25 Watts the replacement 35 Watts.. the 5 Watts in neither here nor there.
Jan 31, 2010 | Kitchen Ranges
How to install a rangehood on a glass splashback with no pre-drilled holes in the glass
If the glass is frosted you can use a clear glass adhesive. Put blobs approximately 6 inches appart on the rear of the glass and push to wall.
Nov 18, 2009 | Faber 36quot; Stainless Wall Canopy...
Rangehood lights not working
I have a Fabyka Range Hood and know three other people who have had this exact problem (i.e both lights go out simulatneously but fan works fine). In my case I was able to pin it down to the transformer used by the halogen lights. This is an electronic transformer so it is less tolerant of power surges and such.
In the case of Fabyka the transformer is a black box connected to the inside of the hood with sticky tape with a black and white wire and two red wires. It is only used for the lights.
It is connected to the AC power via a black and white wire. you can disconnect this and us an LED power tester (about $2-$5 at most hardware stores) and see if you have power when you hit the switch.
In my case it is a 70W 120v to 12v halogen transformer. You can by a replacement off Amazon for about $12 including shipping or you can by a new one from Fabyka for about $30. I would suggest getting a slightly higher wattage transformer (I bought a 105watt for a dollar more).
You will need to disconnect the power before replacing but it is an easy fix.
1. Disconnect the AC power connector (black and white wires.)
2. The red wires coming out are the 12volt lines. If there is a connector, you can disconnect this, if not, you may need to cut these off.
3. Pull the tranformer off the back of the inside of the hood.
4. Cut the connectors off the old transformer. (Unless you buy Fabyka's.)
5. Connect them to the new transformer using wire connectors or crimps. (Make sure you connect black to black, white to white, and red to red.)
6. Make sure you have no exposed wires.
7. Connect to the corresponding connectors inside the hood. Connect the AC connector last.
8. Verify that the lights work properly.
9. Use sticky tape (or Gorilla tape) to attach the connector to the inside of the hood.
10. Enjoy the light.
Jul 17, 2009 | Kitchen Ranges
Change light bulbs in rangehood
I found the instruction manual on the Baumatic website.
Thanks anyway
Apr 18, 2009 | Kitchen Ranges
Faber Perla upper/lower Chimney parts not deep enough
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 13, 2009 | Faber Perla 602599 Kitchen Hood
Palm beach 48"
Me too. I went back to Home Depot. They gave to me the phone number for Hampton Bay - 1-877-527-0313. I will call them tomorrow after they open to see what the deal is. it looks to me like the JDE11 is a mini-candelabra base. The lady in the fans at Home Depot said that all of the light kits were changing to the smaller based halogen lights. BUT, you'd think that they'd carry the light bulbs that have to go in the light kits they sell!!!
May 12, 2008 | Hampton Bay 48 In. Palm Beach in Textured...
Faber Perla 602599 Kitchen Hood Logo
917 people viewed this question
Top Faber Kitchen Ranges Experts
Steve
Bill Boyd
dik stukkien
dik stukkien
Are you a Faber Kitchen Range Expert? Answer questions, earn points and help others
