Question about Psi Cam Spray 3000 Pressure Washer with Honda - 3000HXA
Soap hose hi, i just got a honda 340,3000 psi power washer and the soap hose will not work,can you help me with this thank you..
3 Suggested Answers
bozcro
  • 867 Answers
SOURCE: Power washer problem - water is spraying into my soap dispenser
this can happen if you use the wrong soap, you must use pressure washer cleaner, it does not foam.
Posted on Aug 08, 2009
  • 26 Answers
SOURCE: need a replacement hose for
Check jackssmallenginerepair.com or ereplacementparts.com they should have what you need.
Posted on Jul 25, 2011
Where or how do I hook up the soap hose ?
this unit has a storage tank in the front below the motor , in front of the pump
remove the cap and siphon hose
add solution , than re install hose and cap
you should be good to go
May 23, 2014 | Honda Black Max 2600 PSI Pressure Washer
I have a 2750 PSI pressure washer with a 6.5 hp Honda engine. The soap mixer will not work. Any ideas? Please advise Tahnks
Check the draw tube and soap inlet for a clog. The soap mixer works on siphon action so an obstruction is pretty much all that can go wrong with it.
Jun 27, 2011 | Honda Garden
My Honda 4.0 1800PSI Power washer only has hose pressure when it should have 1800 PSI
hi spray some silicon oil in inlet and outlet then run attach hose back do this everytime you store the washer away it is because the seals dry up always lube when storing.
Jan 15, 2011 | ALL POWER AMERICA LLC AllPower America...
I have a John Deere AC2600Gh power washer and I can't get the soap to work everything else works great it just won't **** the soap up when I am pressure washing I know that it must be something simple to...
Soap will only siphon into hose if there isnt any pressure in the hose attached to the wand.Remove tip from wand and see if it draws soap into hose,back pressure in wand hose will cause the spring and ball to seat/close off the inlet line for the soap otherwise water would blow out of soap line.
May 17, 2010 | Karcher 2500 PSI Pressure Washer
My soap will not come out of the hose. What do i
several things to check, soap only works with low pressure tip installed, are you using correct tip? second issue is on bottom of soap tanks some have a small valve , is it open? is the tube blocked with dry soap or contamination, flusk it with water to be sure.
Apr 23, 2010 | Dewalt 3800 PSI Pressure Washer
I have a GX Honda 160 5.5 and cant get the soap suds to work
Are you using a soap nozzel? If not the soap injector will not work.
Jan 25, 2010 | Simpson WB4200 Water Blaster 4200 Psi Cold...
Aug 08, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Whe using the honda 3000 psi power washer, I've
Are you putting the soap nozzle on the end? Either that or depending on what type of nozzle you have, some times you pull out or push in the nozzle to switch it to soap.
There has to be no pressure to draw the soap, so you either have to put in the soap nozzle in, or if it has an adjustable end, set it to soap by pushing or pulling.
You cannot spray high pressure with soap unless your unit is equipped with another siphon hose for pressure soap.
May 03, 2009 | Garden
Psi Cam Spray 3000 Pressure Washer with Honda - 3000HXA Logo
137 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
