Question about Homelite 'Yard Broom' Leaf Blower
I'VE PULLED ON IT TO GET IT STARTED BUT IT WONT START. IT TURNES OVER AND ITS GETTING SPRK BUT WON'T START
  • 246 Answers
Hello cherokee0568:
Is the Spark Plug Wet After Pulling the Starter for 4 or 5 Times?
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>Pour a Small Amount of Gas (approximately 1/4oz) into the Carburetor Throat (with the Trigger Held at Full Throttle) and Try to Start the Engine with the Throttle at Full.
>>If the Engine Starts and Quits (After Pulling the Starter 5 or 6 Times or Less) then
>>Check the Fuel Filter.
>>If the Fuel Filter is Good, then
>>Remove, Disassemble, Soak and Clean the Carburetor.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace are the Needle Valve and Metering Pump Diaphram.
>>The Metering Pump Diaphram is Under the Carburetor Plate with 4 Small Screws in it.
>>The Dowl on the Diaphram should Just Touch the Metering Jet Actuator Arm.
>>The Actuator Arm is Adjusted by Carefully Bending the Actuator Arm Up or Down to get the Correct Clearance.
>>If you Order a Kit, then Replace All the Old Components with the New Ones in the Kit even if the Old Parts Look Good.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine.
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
2008 vector ltx. i started it and ran for about 2min. i shut it off and went to start it again and it backfired and now just wont start. just turnes over.
clean your plugs , are you getting fuel , ck that first , if they have a electric pump in the tank ck the fuse
Dec 10, 2014 | Big Motorcycles
Help me get it stated up and running again please
Check your fuses. also check the fuel pump fuse if blown the car will not start. If the car turnes over but wont start this the problem ok. it could also be the fuel pump if it's electronic and u are in a quiet area and turn the key in to the on position u should hear the Pump getting power if u dont then the Fuel pump is not working ..Hope this Help's
Jun 25, 2013 | Cars & Trucks
96 jeep laredo stopped running gages quit and won't start even after replacing crank shaft sensor but it turns over like it wants to start
Crank sensor wont have any effect on starting, Cam position sensor would. Also check all your fuses.
Mar 27, 2013 | Cars & Trucks
1991 sun bird le 3.1 car wll not start replaced fuel pump fuel filter and relay turnes over wont start
If you are saying it is not getting fuel pressure to the injectors, do you know if the relay is sending power to the pump ?
Feb 11, 2013 | Pontiac Cars & Trucks
I have a 2004 Silverado 1500. The rear lights won't turn off, pulled all the fuses associated with lights and they still don't turn off. In addition my right turn signal doesn't flash, both the...
Not sure, but I've heard a bad hazard switch can cause strange problems.
Also, if your truck has a body control module that controls interior and lights, that may be your problem, too. Good luck.
Jan 26, 2012 | 2004 Chevrolet Silverado 1500 Crew Cab
Won't start turnes over, but wont start
are you getting fuel ?/
are you getting spark ??
if so check crank postion sensor or cam postion sensor
lmk
if it helps rate me well thanks
May 08, 2011 | 1998 Nissan Pathfinder
My 2000 dodge dakota started clacking going down the interstate than stalled it turnes over but wont start now. what do you think is wrong
first thing to do is a compression check, and check the oil, i suspec you ran low or the oil pressure dropped,
Nov 09, 2010 | 2000 Dodge Dakota Quad Cab
Have an old yamaha getting gas has sprk but won,t start what else should i check
if it has gas and spark then the valve timing is the next thing to check.
Aug 16, 2009 | 1979 Suzuki GS 400 E
2oo3 mazda rx8 wont start turns over and is getting fuel started once and ran for 3 seconds then nothing
Have you checked if it has spark ? Check the spark by removing a sprk plug and connect it to the wire. Place the spark plug agains a groung. Then have somebody crank the engine. It should have spark.
Nov 12, 2008 | Mazda RX-8 Cars & Trucks
Homelite 'Yard Broom' Leaf Blower Logo
312 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
