Question about AT&T Blackberry Curve 8300 Smartphone
BB 8310 : Increase microphone sensitivity
How can I increase the output of my phone's mic ? I want some feature like I had in my samsung phone called "whisper mode"  -thanks
    Brigadier General:
  • 7,752 Answers
That is not possible to my knowledge as yet but try googling it and see
Posted on Jan 31, 2010
My N95 has a loud beeping sound when making or recieving calls so loud you cant hear the other person talk.
It appears that you have microphone feedback between Mic. and speaker.Mic sensitivity to high in usual cases or audio output to high or both. Only solution is to have it repaired by an expert.
Mar 15, 2011 | Nokia N95 Cellular Phone
How can i increase volume for mic iphone 3gs or input volume during calls..they cant hear me clearly..thats my phone problem..iphone 3gs..
Hello
1 .You need to confirm if its the volume or the mic of your phone that has the problem.
2 .If its the mic,your callers would not hear you but you would be able to hear them.
3. You can Adjust the volume of your iPhone by depressing the volume button on the left edge of the phone, close to the top. This will cause a volume indicator to appear, superimposed over the other icons on your screen. This will increase the volume of your ringer. If you wish to adjust the volume of the phone speaker, use this button during a live phone call. You can also control the volume of your speaker when you are using your iPhone as a music player in the same manner.
4. If its the mic,remove the iPhone from the case, as your case may be blocking the device's microphone.
5. Plug the iPhone device cable into the iPhone and into the computer's USB port.
6.Launch iTunes. Click "iPhone" or the device's name in the sidebar in iTunes and click "Summary then Click "Check for Update" and "Download and Install" to update your iPhone's OS.
7. Remove the device cable after the update finishes and insert your headphone jack into the iPhone's headphones port,tap "Phone" on the home screen, tap "Contacts" and tap a contact to place a call.
8. Press the "+" button on the microphone to increase your microphone's volume.
9. If the problem persists take your iPhone to your local Apple Store for professional service.
BEST OF LUCK
Dec 15, 2010 | Cell Phones
I have a LG Shine KE970, and the mic is very low
when u make a call ensure the volume is @ max press the increase volume key when u r in a calll or press the right arrow key or move the joystick towards the right to increase the volume
Jul 12, 2009 | Cell Phones
Microphone volume goes down automatically
Go to control panel and select the sound option
There you will find microphone settings that are enabled, one of them is set to on and adjusts volume automatically as the noise increases, jsut disable that option
Cheers
Jul 08, 2009 | HP Pavilion dv6000z Notebook
Galaxy 2547
Is there a dial marked RX Gain? Does this radio have this feature?
M3ODQ
Feb 01, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Change Mic on BB 8310
Sadly I would send it to a repair shop. Since it is soldered to you mainboard you run the risk of actually damaging the phone if you attempt to remove it.
Jan 16, 2009 | AT&T Blackberry Curve 8300 Smartphone
Pcchips A13G+ motherboard sound issues
You may not have a choice. The jack could be loose or have a bad solder joint. If the microphone is "staticky" on this system but not on another, then increasing the volume will only increase the static.
You can try a condenser microphone. Condensers require their own power (battery) and output a MUCH higher signal. High enough for the Line-In jack.
If you are using the microphone for voice chat or internet phone or gaming or similar, I STRONGLY suggest a USB headset, such as you can get from Logitech. You wouldn't believe the quality difference.
Jul 06, 2008 | PC Chips PCChips A13G+ v3.0 Motherboard -...
What is caller iq and voice enhancer and how do they work
caller iq(ID) is simply the number(or name is you have stored it) that displays when someone calls you.
It is a feature available on most phones incase you do want to hide your number from the person you are calling but also mind you that it is network supported which means that some network providers do not allow you to hide your number from people you call so you wont be able to make calls at all should you hide your caller ID.
Voice enhacer(s) also works in a way to improve your audibility when you speak........it is to improve or increase your mic volume or sensitivity when you make calls.
this feature is mostly not available on most handset. They mostly are made automatic to work in certain conditions.
An example is like this: you are in the market place and the noise is so much that the person you are talking to on the phone can hardly hear you..............with the manual voice enhancer you can tune your mic volume to increase your audibility, but then the automatic voice enhacer will adjust to the condition(realising it is a noisy one) and will increase the mic volume for better clearity in speech.
so having a phone with such functions you are assured of a good product.
May 11, 2008 | Lands Phones
Microphone freezes my computer when i use it
First you have to check the connecting the microphone in the right port. There are three port output, input and mic.In the mic port you can connect the microphone wire.
Then it will not work properly check the sound properties in the control panel for increase the volume in the mic properties.
please try it and inform to fixya.com
May 07, 2008 | Computers & Internet
Microphone
you cannot use any other drivers other than realtek, as this is what you have built into the motherboard, any other driver will not recognise the hardware you have installed. The mic sensitivity is altered by using the volume slider and by ticking the mic boost option in the sound properties
Sep 01, 2007 | Microsoft Windows XP Professional With...
AT&T Blackberry Curve 8300 Smartphone Logo
672 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
