Question about Dishwashers
Will not drain
Dishwasher won't drain. i hear noise from air trap
  • 460 Answers
DISHWASHER WON'T DRAIN  VIDEO? copy n paste this video.
http://www.youtube.com/watch?v=nr6tIO5iNSc
you may solve 2 problems with this video information.   If you won't please let us know.
Was this helpful?
Posted on May 13, 2009
Bosch Dishwasher stopped draining
If you hear the pump running, but little water drains, then check hose, and clean out debris trap at bottom of dishwasher. That gets plugged and needs occasional cleaning.
Sep 04, 2014 | Bosch Dishwashers
Drains slow
This is impellors that are worn.
Mar 25, 2014 | Frigidaire Dishwashers
Water won't drain out
Hello Veronica Spellman - Have you recently cleaned the filter? This can be doing by a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, pits, etc. You should simply be able to grasp handle, lift out, empty and place it back. Also is the unit making a grinding noise? If so, I personally recommend consulting a professional to move forward accurately and assist with the repairs. The dishwasher could possibly have a faulty drain motor/pump.
Feb 24, 2013 | Frigidaire 24 in. PLD2850 Built-in...
Model 655-15974990 won't wash or drain
What DOES it do? Just fill with water? Or doesn't it even do that? Do you have any lights on or flashing? Do you hear any noises when you try to run it?
Oct 12, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishwasher not working.... when i close the dishwasher and turn it on i can not hear any water running and there is a pool of water at the bottom that will not drain
Hello, How long has your dishwasher been do this? Have you washed dish's in it? Also, these German made dishwasher run on less than 2 1/2 gallons of water. These German manufactured dishwasher machines run really quite. Because of the German water conservancies laws. They limit the amount of water dishwasher and washing machine can use. Also, there is no storage hot water system in there homes, it on demand hot water. You can't hear the motor running and about the only thing one can hear is maybe the water washing the dishes.
Now, the water at the bottom of the dishwasher, if the drain isn't connected up under is the sink drain and trap area or the garbage disposable in the sink. but some place lower on the drain pipe. You will not have a spiffing effect on the the bottom of the dishwasher, it the same with washing machines. One the discharge pump starts sucking air, it will not drain the dishwasher. The siffen effect works if the water is below the outlet for the drain. Example: Home owner have the new washing running and continue fill with water. Why, because the drain pipe end is below the the bottom of the washing machine tub. It fill up with water and siffen action continues emptying the tube will it still filling. One heck of a water bill.
GB...stewbison
Aug 25, 2011 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 23, 2011 | Dishwashers
I have a new furnace with a humidifier. Both work fine. The trouble is, the water running through the hose to the drain makes a LOUD dripping noise when it runs into the drain. Is there some way to stop...
Not seeing exactly what you have. I am guessing...does the humidifier have a trap on it coming out of the furnace?. Is this some type of over flow from the humidifier? If so...
I would suggest running a 3/4' pvc pipe from the hose coming off of the humidifier and at a point lower than the humidifier install a trap...like what you see under your sink. Come out of the trap and run the solid 3/4" pvc to the drain and put a 90 elbow turned down into the drain. Buy installing a trap you should not hear the loud dripping noise.
I hope this helps you...Jim
Feb 20, 2011 | Heating & Cooling
Gargling noise
1# if there is any shortage of gas this type of noise you can hear,but this happens only if you feel there is less or insuffient cooling .
2# check water drain point,may be there is air trap and making noise.
Jun 03, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Loud vibrating/humming noise
Okay...based on the model number, this is a Frigidaire manufactured dishwasher. If you go to searspartsdirect.com and type in the your model number in the Search menu, you will find a useful illustration under the "Motor and Pump" heading. The drain pump is listed as item #60 in the drawing. Before you go through any major dis-assembly, check to make sure the pump is securely in place and not loose. Sometimes the pump comes loose from the mounting bracket and vibrates. Also, sure nothing is laying against it causing vibration noises (I've seen this before). If the solution is not that simple, remove the spray arm assembly inside the dishwasher and inspect all the debris traps under the spray arm assembly. The wash pump and drain pump sumps are located here. Check to make sure there's nothing obstructing the input to the drain pump. Lastly, if all else fails, remove the drain pump and inspect the impeller. If the you've inspected everything and still have the noise problem, replace the drain pump. The motor could possible be failing. The part number on the Sears website is 154580301 and costs about $40. Repairclinic.com has the same part listed as item #1257094 for $37.50 if you wish to do some comparable pricing.
I hope this helps you. If you need further assistance, please post back and let me know.
PS Even the quietest of all dishwashers will make some noise. However, if it has gotten to the point where you can hear it in the next room, you probably need to inspect to find the source of the problem. This is not true with all dishwasher manufacturers, but in many cases, the only difference between your "Quiet-Pack" line and regular low-end models is added insulation behind the door and lower panel to help quieten noise.
Apr 21, 2008 | Dishwashers
Dishwashers Logo
67 people viewed this question
Top Dishwashers Experts
