Question about Mitsubishi WS-55809 55" Rear Projection Television
Mitsubishi HD1080 series 65 concave picture screen w/lines
I have a Mitsubishi HD1080 series 65" TV, and the picture quality seems to be going. The picture will suddenly go concave on both the top and bottom of screen and at the same time a lot of colorful horizontal squiggly lines go through whole screen. Will sometime stay like this for a long time and other times just a few seconds. Does not seem to matter if TV is warm or cold. And it is getting more frequent. Is there any soultion to this problem?
  • 2 more comments
  • eva8773 May 13, 2009
    Which im thinking needs to be done by a TV repairman, seeing how i have no idea what that means. Is this fix worth doing or would it be better to just get a new one. In other words is this an expensive fix?
  • phplayr May 19, 2009
    I had the same problem with a 55" and then it just shut itself off. now when I turn it on, it shuts off after 2-3 seconds. no pictures, just green power LED.
  • salangel May 23, 2009
    I have the same problem with the concavity and the color appears as a double vision as well.
  • thecarsons May 26, 2009
    Yes, I have the same problem. Sometimes it lasts just a few minutes. Its been this way for the last 2 days. Any idea of the cost to repair?
2 Suggested Answers
  • 64 Answers
SOURCE: picture quality
Contact your local service rep as this sounds like a "not so easy fix' related to the main board or power supply (known issues with Mits boards, especially the capacitors). Cleaning, resetting, re-configuring will not likely make any difference. Verify the problem occurs across all input modes (such as DVD, etc). before taking any service actions.
Posted on Aug 01, 2009
On my HD1080 Mitsubishi projection flat screen the picture is bowed on top and bottem and it look as if the projectors themselves are offset, but the picture is clearer as you come toward the center. If I...
You have poor contacts and or dry joints. Resoldering on the convergeance panel and powersupply/line timebase board will probably fix it.
It should take less than an hour in labour terms.
Feb 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
I have a Mitsubishi HD1080 46 inch TV. The projection shows a concave picture and there are red and green outlines like a 3D image but without the glasses. This problem has come and gone in the past now...
I have the same problem. At first I thought the TV just needed some warming up because after a while it would resolve itself. Now, even after hours of being "resolved" it will occassionally revert back to the concave image! Have you gotten any feedback or resolution?
Oct 19, 2010 | Mitsubishi Televison & Video
Moving a Mitsubishi HD1080 Medallion series 55
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Nov 17, 2009 | Televison & Video
Picture quality
Jun 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Color loss on mitsubishi 73" medallion hd1080
TRake the fron grill off and the front board 6- screws on my 65inch there are three adjustment knobs one of them wil adjust the huge
one the whole screen,if not that,I have heard mold growing on and the inside of the blue bulb because it runs the coolest out of the three.
Jan 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red and blue colors go across the screen. picture looks concave.
Greetings joanne7,
The issue you are having could be caused by your television needing the convergence adjusted. During production your televison has the three picture tubes that are converged to form a single image on the screen. Over time these can come out of adjustment.
If you go to this link http://download.jazel.net/misc/filecache/b8/b89bca4c8b740315d378e8ed030461c5_1227-517SeriesOwnersGuide.pdf and check pages 57 and 58, it gives you a very detailed guide on adjusting your convergence. I am aware this model number is slightly different than yours, but I own a 47" Mitsubishi and this is the exact procedure we use to do our convergence so I am confident it is fairly universal.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 25, 2008 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi WT-A42 projection 42" HD1080 series
It sounds like your regulator circuit is defective. Not an expensive repair, maybe $200.or a little more.
Apr 08, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Concave distortion on top and bottom of screen
Bad convergence IC's ....change both for reliability...part number
STK392-570...located on center PC board.................T.
Feb 11, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
1,077 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
