Lost reception Hit reset button and lost all signal for tv
  • 2 more comments
  • Johnnytyler Oct 14, 2007
    Cancell I got it figured out
  • Johnnytyler Oct 15, 2007
    I had already solved problem and that was not it. But thanks for trying.
  • Johnnytyler Oct 17, 2007
    There is no problem any more. I dont know how else to say it. ??
  • dodong65 Dec 01, 2007
    the tv i bought is about 5 yrs old, just the other day we subscribed to time warner cable. at first the tv was working and then when i used ther control i wanted to get the information of the show i was watching, suddenly four number ones appeared on all corners of the tv and then the volume went out. i tried turning it off and unplugging no luck. their are shadows that appear but very paint. I have changed some of the settings, but i dont know how to access them. pls help
  • 790 Answers
Ok john! go to menu then select the CABLE/TV/AIR, selection then select the TV mode! then select the auto search or auto program! the you can see now the channels is searching!
Posted on Oct 17, 2007
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 17, 2007
    ok john! i think i can solved your problem! merry christmas in advance john!
I was driving along and I got a message "lost satellite reception.
Put it on the dashboard when it is acquiring signal, that helps it faster. If it locks up like that, disconnected the power for 20 seconds and then power it back on.
Oct 15, 2015 | Garmin nuvi 350 GPS Receiver
I lost the vidio but had audio,so I started hitting buttons and hit the reset button on the Sanyo remote. After that I lost everything and can not get anything now. ?
The whole system might have been reset to its factory settings, after you hit the reset button. Do a re-tune, and do all other adjustments similar to previous screen, before you hit the reset button. There is no other fault. Refer its user manual for details.
Nov 27, 2013 | Sanyo 42 in. LCD TV
Garmin 545s lost gps signal/reads gps error on satilitte page
Lost Satellite Reception - the unit has lost satellite signals. Check
antenna connections or try moving to a location with a clear view of
the sky.
Jan 11, 2012 | Garmin GPSMAP 545s GPS Receiver
Lost signal
Have you tried to push the tv input button? Sometimes when a button is buy accident it changes the input on the tv. Hope this works, let me know.
Good luck, Toni
Nov 29, 2011 | Televison & Video
My viewsonic N3751w LCD TV won't receive air signal. It has a built-in digital tunner so it should be able to receive several air signal without a need to have a digital to analog converter
Check that your antenna is sufficient for your location and oriented correctly. Try antennaweb.org for the most likely channels; tvfool.com has a much greater list of channels and the antennas needed to receive them. Both sites assume external antennas and warn that trees and buildings around your location may cause interference.
If you have a splitter connecting one antenna to several TVs, consider using an amplifier to ensure that the TV gets sufficient signal strength. Remember digital TV is has all-or-nothing reception issues.
If you previously could pick up the stations with this TV and suddenly lost them, try resetting your TV. Unplug the unit for at least 10 seconds. Also restore the factory default settings and then rescan for all channels. The reset is possibly Menu, Options, Restore Default or Menu, Setup, Memory Recall. (Viewsonic has changed its menus at intervals so look for something similar). Once you find it, click enter then left or right arrow to YES, hit enter again. Then hit menu twice to exit the OSD menu and then re-enter the menus before trying to rescan channels.
Also check that the TV is looking for OTA and not cable signals. Check that the tuner is still working by retrying the scan in a spot you know that the antenna captures a stations signal. Make sure your antenna cable hasn't been damaged by anything.
If you recently had a power surge (lightning strike) near the antenna or cable, you may be in need of a new tuner. (BTDT with an older TV)
I hope this helps.
Apr 24, 2010 | ViewSonic N3751W 37 in. LCD Television
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
Set top box reset has lost input signal
Do other inputs work like DVD player and so on? If so contact your service provider.
May 01, 2017 | Televison & Video
After an electrical storm last night we have lost ITV, Ch 4 etc on Digital, BBC and Sky on freeview are fine. All analogus signals are of very poor quality. Any ideas please?
Electrical Storm normally damage Tuner in TV.
Symptoms in tv like poor analog tv signal reception shows replace TV Tuner.
Regards,
Sep 03, 2008 | Televison & Video
Sony Qualia 46" TV Model # KDX 46Q005
This would mean that your signal is being lost. Instead of snow like from a analog signal you get digital breakup when you get low reception. You need to reposition your antenna or get a better one with a little more power. Nothing wrong with your tv though just not strong enough signal.
Thanks
Josh
Feb 08, 2008 | Sony QUALIA 005 46 in. LCD Television
Televison & Video Logo
145 people viewed this question
Top Televison & Video Experts
