Question about JVC HD-52G786 52" Rear Projection HDTV
Tv problem jvc hd56g786
The tv was working fine, then the picture got darker and you could hardly see anything.  So I turned off the tv and now it won't come back on.  Also, the Power Led and Lamp/Program blink simultaneously.  What is wrong with the tv?
  • 3 more comments
  • barkingdogs Feb 28, 2008
    I have a similar problem but instead of the tv getting darker it just shuts off. Then the led lights blink rapidly together. I have already replaced the lamp once before a year ago and now the tv has done the same thing again. Should a lamp burn out in just a year? Also my model number is a bit different and I can't find any documents online for this model. The number is JVC HD-52G456 52" screen. Thank-you Esther
  • Anonymous Mar 20, 2008
    my tv does the same it stays on for a few minutes then clicks off,,the lamp indicator lights blinks continuoesly now the tv doesnt come on
  • Anonymous Jul 07, 2008
    I have the same problem. The tv kept shutting down and then it finally would not turn on. Now, when I attempt to turn it on the LAMP and Program lights blink simultaneously. When this happens I can only turn the tv off by unplugging it.
  • epboyd Jul 07, 2008
  • Anonymous Sep 03, 2008
    when i turn the tv on the ligth just blink and no picture at all
Your lamp bulb is probably finished so get a new lamp bulb they are easy to replace just look for a small panel on the side of you tv all you need is a flat head screw driver to open the panel and you should be able to pull out the lamp bulb
Posted on Nov 04, 2007
Hi Guys, I have a JVC 32T55EKS TV & the picture is overly dark. When the picture goes through the set-top box the picture gets even darker. The brightness is turned up fully & I have accessed the...
U turn on the contrast level to the max,if still not watchable,tv cathoray tube is dying,radiaton is disappearing.Time to buy another tv.
Feb 14, 2011 | JVC AV-27230 27" TV
The picture gets darker and darker till i can barely see anything. everything else works fine
I'm sorry to tell you but this is caused by the aging of tube. There's nothing more that can be done to save this tv, time for a new one.
Aug 18, 2010 | Toshiba CZ27V51 27" TV
Picture has become progressively dark 27'' TV JVC AV-27320
disgaussing will not help this problem..i am scared your picture tube problem or try to change the crt socket first it is not cost much
Jul 01, 2009 | Televison & Video
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
Mar 24, 2009 | JVC AV-27920 27" TV
Sorry to tell you but JVC is a well-known un-reliable brand and if it's cheap, probably even worse. U may have screen burn from leaving a games console on while plugged into the tv, even if its not showing the game, it will burn it onto the screen. :(
Mar 24, 2009 | JVC AV27F476 27" TV
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
MY JVC HD56G786 TV
If the Mirror broke while the TV was sitting upright, the pieces of glass got down inside the light engine and the cooling fans. I don't think you took the light engine apart to clean out all of the glass so the main cooling fan is probably not running and causing the warning. There is no sensor for the mirror. Did you remove the chassis to clean the glass? You cna remove it again and try powering it up out of the cabinet. There are four fans that need to be running. If the light engine is filled with glass the fan at the bottom of the air exhaust will not turn.
I am fairly certain that since the TV was discarded there is more wrong with it than a broken mirror.
Jan 22, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC convergencehas to be adjusted everytime the TV is turned on
You will need to enter servicer mode to do the alignment then
save changes.....info is in service manual........
Does your set have an auto-focus selection ? Try that first...T.
Dec 26, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC HD-52G786 52" Rear Projection HDTV Logo
1,343 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
