Question about Toshiba 46H83 46" Rear Projection HDTV-Ready Television
Toshiba 46H83 No picture. Was working fine, heard a pop and now the tv won't turn on
  • 150 Answers
Anthing could have happened from a blown fuse to a transformer. Dont tinker with it from the the outside get a repairman out there asap.
Posted on May 13, 2009
  • Jerry Naidoo May 13, 2009
TOSHIBA TV NO PICTURE
Sounds like blown invertor board that powers the backlights (if it is LCD or PLASMA). If your lucky and its just the invertor board blown it could cost anywhere between £50-£150 for new board (without labour).. if you are UN-Lucky, then the backlights themselfs may have blown which is *usually* an un-economic repair.
Apr 05, 2010 | Toshiba 46H83 46" Rear Projection...
The toshiba 46h83 46in rear projection tv comes
the red flash you are talking about im assuming is the screen going red
that usualy means a red picture tube they break down
one way to tell turn the red screen control counter clockwise and see if you can control the tube gain
and then you can lightly tap on crt neck and i do mean carfuly and see if it flashes it most likely will and you would need to change the crt and reset it up
Nov 02, 2009 | Toshiba 46H83 46" Rear Projection...
Turned on tv have sound but no picture. toshiba 46h83
Most likely your convergence IC's are bad along with the two 5 amp pico fuses on the board to the left up front.
Oct 03, 2009 | Toshiba 46H83 46" Rear Projection...
Want to check fuse on 46h83 toshiba
only fuse I know is near back of tv inside power section right next to the power cord input ... my first thought tho is damaged capacitors inside same area ... good luck getting it apart ... I took mine apart but difficult to figure how
Jun 10, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 HD Projection TV with distored picture
if you are using an areal for your tv move your areal and see if it works or do the tuning for it .
Apr 19, 2009 | Toshiba 46H83 46" Rear Projection...
Toshiba 46H83 won't turn on...replace bulb???
this sounds like a power supply, or a fault convergence board.
did you notice any problems before it stopped working?
Nov 14, 2008 | Toshiba 46H83 46" Rear Projection...
Toshiba 46h83 tv projection not full orizontal pic
if you go to the menu on your tv it should show picture you may need to snoop around for it but its there and when you do find it adjust it untill you got a nice picture about the tv not being full on the screen try buying wide sceen movies it should help but the adjustments should help the most
Jul 30, 2007 | Toshiba 46H83 46" Rear Projection...
Toshiba tz50v51 popping sound
Possible problems: * The TV set may be unplugged. * A fuse or circuit breaker may be blown or switched off. * The remote control unit (RCU) may be disabled. Solutions: * Make sure the TV/VCR are plugged in and the wall switch is on. * Check the fuse or circuit breaker. Test the outlet with a lamp. * Replace the RCU's batteries: if this fails exchange the unit.
Jan 18, 2006 | Toshiba TZ50V51 50" Rear Projection...
Toshiba 46H83 46" Rear Projection HDTV-Ready Television Logo
115 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
