Question about Welding Tools
No arc. Power and Air OK
I have a Miller Plazcut that stopped woking. At first it worked intermitently. Air pressure and power is OK. I opened up the torch head and found plasma in side the cup, cleaned it out, even tried new nozzzle and cup. At first I was getting air at the nozzle. Power lamp is on, but ready lamp wont stay on, when I toggle the ready Switch. At one point the head got hot (after I cleaned it). When I squeeze the trigger and then toggle the ready switch, I get sparking at the spark gap, but only when the HI/LO SWitch is in the HI position. But no matter what I do, before and now, It won't produce an arc at the tip. One other thing I did notice, is that I found a large cut (some wires still connected)in the high voltage wire. It was not arcing, but I did rejoin the wire and provided ample insulation to avoid any possible future arcing. Is there something special about the torch? There are two electrical connections on the torch which according to the wiring diagram are supposed to act as a loop (closed swich) Does the torch head contain some kind of fuse or fusible link that blows when there is trouble or internal arcing. I checked these two connections with an ohmeter, and it shows an open. Under what conditions do the 3 time delay modules (TD1 TD2 TD3) fail. As I tried to troubleshoot the problem, things progressively woorsened. I have two of these units with the same problem. Please help.
  • kevin_max
    kevin_max Jan 20, 2010
    Is yours a Miller Plazcut. The plazcut model is the only unit I know of that has two trigger wires and two additional wires of the same size going to the gun, in addition to the high voltage lead. A total of 5 conductors plus gas hose.
    Champion:
  • 225 Answers
If the main power cable is cut that is your problem,unit uses high frequency.the two leads go to the gun trigger back to unit,no fuse or fuseable links in the gun.
Posted on Jun 28, 2009
Did you ever resolve this problem as I have the same problem and would like to know what to check.
Posted on Jan 20, 2010
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
Miller welder problem
the current setting is not working correctly
indicates that the amp setting for the wire is too low or if it is an inverter , the volts setting is far too low
Jul 26, 2017 | Welding Tools
Kubota engine
machine is most likely ok other than the fact it is a miller.if it aint lincoln its stinken. yue are to hot try speeding your hand speed and as the rod burns it gets shorter if you long arc it gets hotter.
Aug 15, 2013 | Miller 907068 MILLER TRAILBLAZER PRO 350D...
Spectrum 2050 plasma cutter . Cutter blows air and stops when trigger is pulled no pilot arc or any cutting when trig is released air flows again and stop after 10 sec new tips was working the day...
Check compressed air pressure is in limits otherwise unit will cut out. Try adjusting the pressure up. also make sure the supply pressure is correct as it may not be your plasma cutter at fault.
Jul 30, 2010 | Miller 903777012 SPECTRUM 2050 PLASMA...
Wire won't feed or arc fan runns
Look for a reset button on the case. Make sure that you have power to the machine and at the power socket. If everything looks ok outside, you may have to investigate your warranty. Good luck!
Jan 04, 2010 | Miller matic 140 Mig Welding Package W/As...
Unstable arc..Millermatic 250. arc not steady
Your windings inside are aluminum, they may have loosened up where the positive lead hooks on to the transformer inside.
I had a miller and the wire melted there, you can re-loop the wire and re-fasten it if it melted short enough if this is infact the the problem when you take the cover off..
Dec 19, 2009 | Welding Tools
Arc starter on sync 350 interferes with equipment
It's the high frequency, ground the case of machine, work lead connection and work table, do not chain grounds together, this will cause a ground loop.
Jun 25, 2009 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Arcing before pulling the trigger
does this unit have a high side and a low side if it does plug it into the low side and try it.
May 27, 2009 | Miller Welding Tools
Operator instructions
When all else fails, Read your owners manual.
Miller has a good site. millerwelds.com
Look up Miller Plazcut, the pdf contains instructions on how to use your cutter.
Apr 11, 2009 | Welding Tools
Miller 2050 that will not spark.
This is relative to 3 causes , contol board , pwm board or torch
Feb 28, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Welding Tools Logo
1,786 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
