Question about Kyocera Mita KMR-1810P Laser Printer
WHEN POWERING UP MACHINE FLASHES C-610 CHECKED
WHEN POWERING UP MACHINE FLASHES C-610 CHECKED LAMP AND THERMISTER BOTH CHECKED GOOD?
I CALLED HY TECH DEALER SERVICES AND THE TECH TALKED ME THROUGH THE RESET PROCEDURE. HY TECH DOES BOARD REPAIR AND TECH HELP. 1-800-883-1001
THANKS ANYWAY ROBERT.
Posted on May 14, 2009
Runco cl-610 projector
Likely the fan blades are dirty and out of balance. If this projector is in a dusty or smoky place you will need to clean them (or have them cleaned by a tech) often. If you are not good with electronics, I suggest taking it to a dealer. If you can get the covers off properly, you will need use a can of compressed air to carefully blow out the projector and fan blades.
Jan 05, 2013 | Runco Lamp for CL-610 Projector
RICOH MODEL 2015 WHAT IS SC542
Low fuser temperature during warm up. This means that the heater lamp is not coming on or if it is the machine can not see the heat. This is most commonly caused in these Ricoh's by thermister failure. The thermister is a small electronic part that reads or monitors the temperature of the heat roller. The thermister fails, the machine fails to see the machine heating up and pop goes the SC542. The thermisters are pretty in-expensive at around $20.00. The expensive part is usually the labor to have a tech come out and change them.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 22, 2010 | Ricoh Aficio 2015 Copier
Hi My name is Dieter and I have a Pioneer Elite Pro-610-hd which keeps loosing the picture and sound.
The tv "LAMP" LED light indication front of the screen panel flashes?When was the last time u replaced the tv projection lamp on this tv?If the last time u replaced the projection lamp was like 1/12 or 2 years ago?The tv been on and used like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
Sep 19, 2010 | Pioneer PRO-610 58" Rear Projection...
Kyocera KM1530 photocopier. What does C610 mean? It is comin gup on the display when we turn our machine on.
C610 = Fusing Unit Heat failure. The fusing unit is the part that gets hot and "fuses" the toner onto the paper. The C610 code means that the fuser is not heating up as it should. The 2 most common causes are thermal fuse failure or thermister failure. The thermal fuse will keep the heater lamp from coming on while the thermister failure would cause the machine to not "see" the temperature rising as thus shut down the machine. Either way you will need a service company to come out and diagnose/repair the machine. You must also use the factory service mode to reset the fuser failure code.
Good Luck and Thnak You for using Fixya.
Sep 13, 2010 | Office Equipment & Supplies
Panasonic PT-60LCX64 does not power up
There could be a possible failure of the Ht circuit, check on your Ht Drive output trans, the LOT, any shorting in the HT capaciitors, short in the LT line. You will need to probe into the power side as there is a safety switch off. the microcontroller is working fine and hence trace carefully looking for damaged resistors, capacitors or transistors in the power side.
Jun 29, 2010 | Panasonic PT-44LCX65 Television
Asko washing machine
f4 code is sapose to be the thermister, i'm looking for whosale parts supplyer can you help?
Mar 13, 2008 | Washing Machines
Km1505 digital copier machine
I would suggest that you confirm proper fixing heater supply turn on from Power source PCB to fixing unit if possible. Or replace it with a known good one (part# 2A1280551). If you are getting a low AC voltage reading at the heaters when they should be heating you may have a defective Triac or relay on the power PCB. If that is all OK you are probably looking at the main PCB as a source of the problem as it sends turn on signals to the power PCB.
Dec 29, 2007 | Office Equipment & Supplies
OKI-B8300 MONO PRINTER
H4-01 Heat roller low temp is correct.
You machine has a fuser unit that it uses to bond the toner to the paper, it does this with  a heater lamp heating a set of rollers that the paper passes threw after it has printed.
Your machine monitors this unit to regelate its temp, your machine is sensing via a thermister and thermal fuse the temp of the fuser unit is not hot enough to enable use, this would mean the heater lamp is blown, thermister is faulty or thermal fuse blown 95% chance it's the lamp,
What one normally does is replace fuser assembly with new this is not a user thing it requires a tec, but if your into it, it is the hi voltage hot bit near paper exit.
Oct 30, 2007 | OKI B8300 Laser Printer
TV turns off aftering powering up. red LED flashes 3 times.
3 red blinks means th lamp door in not on. if you have installed the lamp door corectly and it still does this solder all three pins together on the door switch.
Oct 08, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kyocera Mita KMR-1810P Laser Printer Logo
169 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
