Question about Maytag M7DH65B2A Dehumidifier
My dehumidifier was running fine until the other day when the water would leak out rather then collect in the pan. Does this mean I need a new dehumidifier?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 75 Answers
Before you go out and spend money, check the drain hose to see if mold may have built up in it blocking the drainage.
Posted on May 15, 2009
Dehumidifier leaking
I have a duracraft DD-TEC16E I have had this for 12 months and has been working perfectly until today , I have noticed the water is not all collecting in the tank it's leaking on the floor . Any possible solution please?
Feb 14, 2014 | Dehumidifiers
Whirlpool gold dehumidifier leaks water on floor and we do not use hose just the pan, puddles of water on floor.
check your condensation hose for leak or the pan may have a crack in it or it runs too much for the water to disapate
Oct 23, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Water is not collecting properly in the bucket. I ran it for an entire day, and only about half an inch collected in the bucket while more than that amount of water leaked from the unit. There was a puddle...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 30, 2011 | Soleus 8649045FB Dehumidifier
Our machine is collecting water but I have a drip coming from the bottom onto the floor? It is coming from the behind the collection area?
This could be from a couple things, first is that as units get a little older, the drains and pans start to clog because as your removing water from the air, your also removing dirt. Sometimes this dirt builds up on the bottom of the pan and over time, it clogs the drain. This will allow the pan to overflow and spill over on the side that has the lowest spot. One way to tell is to shim up the back about an 1/8th or an inch. If it leaks from the front now, your drain is clogged. If it drains fine and the drip in the back goes away, you have corrosion in your pan and you'll need to take it apart an clean it, aluminum tape it, and silicone it to get back to full operation.
Sep 28, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
My Danby Silhouette DDR556RH dehumidifier is less than 2 years old (out of warranty) and is no longer drawing out the humidity. First, the hose connection to the sump pump stopped working (I have cleaned...
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 21, 2010 | Danby DDR556RH Dehumidifier
My dehumifier is leaking. The collector pan is fine. I took the covers off and could not detect anything. It is pretty simple...air blows by the coils, condenses, collects and runs into the pan. Looks...
TRY IT ON LOW FAN SPEED AND SEE IF IT LEAKS , MAKE SURE IF THERE IS A HOSE OR SMALL DRAIN PAN UNDER COIL   THAT IT IS CLEAN AND FREE OF DIRT .SOMETIMES ON HIGH WATER IS BLOWN PAST DRAIN PAN AND DRIPS ON FLOOR , THIS MAY BE A BAD DESIGN. IF THERE IS A FILTER CLEAN IT
Apr 20, 2010 | Maytag M7DH45B2A Dehumidifier
Does not collect water (also 2 years old).
the evaporater coils rot out and the freon leaks out. thats about all the longer these newer ones last now.
Jul 09, 2009 | LG LHD45EL Dehumidifier
Dehumidifier running but not producing water
Sounds like your relay switch isn't connecting....
Apr 29, 2009 | Maytag M7DH65B2A Dehumidifier
Dehumidifier does not collect water.
If your dehumidifier doesn't seem to run often but the humidity in the room is high, try adjusting the humidistat control on the dehumidifier to a dryer setting. If the dehumidifier seems to run constantly, but there's little or no water in the container, there may be a problem in the refrigeration system. Try cleaning the unit. If that doesn't work, you can't repair the refrigeration system yourself, you need a qualified appliance repair technician to do that.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Aug 05, 2008 | Haier HDN655E Dehumidifier
My unit does not collect water any more. It was fine until I lent it to my brother in law and it was returned damaged. Do you know how to fix this
Dec 06, 2006 | Kenmore 54501 Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
257 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
