Question about Toshiba Satellite Pro 4600 Notebook
When A USB thumbdrive is plugged in, it is reconized but then it doesn't show a drive letter in "my computert" in order to transfer to or from the drive. The safe eject tab is present and does give a drive letter there but not where I need it.
    Problem Solver:
  • 6 Answers
You should try manually assigning a drive letter in the computer management section.
At the desktop:
Click Start
Right Click on "Computer"
Click "Manage"
Windows should ask for administrator permission if youre using Vista. Just click continue.
A window with three panels should open. On the far left panel, click the "Disk Management" option. This might take a few seconds to load.
In the middle pane you should see a list of all the drives on top, and a more detailed one underneath with what looks like bar graphs to show the size of your hard drives.
Look for a disk the same size as your flash drive that doesnt have a drive letter. When you find it just right click on the little box on the left middle panel
it should say something like:
Disk #
Basic
##.## GB
Online
And then click assign drive letter. There will be a pretty quick wizard which lets you pick what letter to give your drive, and then youre done.
Oh, never, ever change the drive letter of the "C" drive. Your computer will not work!
Posted on May 13, 2009
    Dedicated:
    Visited the website for 20 consecutive days.
  • 90 Answers
Goto Computer Management (you can type COMPMGMT.MSC in RUN box)
then goto Disk Management, point out the USB device there, right click and assign it a drive letter.
It should work.
hope it helps.
thanks.
  • 221 Answers
You should plug in the thumb drive, wait for it to recognize it, and then right-click on My Computer. Select the Manage option. Inside the Computer Management window, go down to Disk Management on the right side. The left pane will show you all of your local drives (hard drives, CDRW, USB, Flash, etc...). If you see your thumb drive listed in the drives, you can right click on it and select "Change drive letter and path". This will allow you to pick the drive letter you want as long as it doesn't interfer with any other existing drive letter.
How do i connect crw-785 to compaq armada e500
This e500 has USB1.0 and transfer rate will be slow. If you use Win 98 then install the USB driver (get on web) first. Install software then plug in the USB lead from the crw-785 and don't forget to plug in the DC adaptor for the drive, (e500 USB port does not have enough power to run external drives other than some older thumbdrives).
Feb 24, 2015 | Compaq Armada E500 Notebook
Missing driver
In general XP does not need drivers for thumb drives.
You can try use it on a different computer and format it there.
Also sometimes the drive does NOT show up because there is an
drive letter issue. You can see that in Control panel - Administrative tools - Computer management - Disc management and there it should show up..change drive letter and :-)
Oct 26, 2013 | CenDyne 16GB USB 2.0 Flash Drive (Black)...
Setting of USB boot
http://support.fujitsupc.com/CS/Portal/supportsearch.do
A6110/A6120 BIOS Guide
Boot Menu
Nope. No option for booting from USB
1. Floppy Disk Drive
2. Drive0: (Harddrive)
3) CD/DVD Drive
4) NETWORK
5.
6.
7.
Excluded from Boot Order:
USB MEMORY
USB Harddrive
Back before USB thumbdrives (Flash Drive, whatever), came on the scene; the Floppy Drive was used. Then the Optical Drive came out.
(CD/DVD drive)
Transfer the boot data to floppy disks, or a CD/DVD disk.
Make sure they are bootable..........
Regards,
joecoolvette
May 06, 2013 | Computers & Internet
How to tranfare recordings onto a usb
transfer a recording onto a USB stick ,quite simple right click on the item to transfer then it will come up with a list of what you want to do like copy to cd or another hard drive or the USB providing its plugged in it will show as the name of the USB stick or drive whatever letter the computer affixes to the drive ,simple well it should be
Dec 10, 2011 | Lorex SG19LD804-161
My computer will not reconize the external hard drive. The red light is on and the blue light is blinking. Help!
Listen closely to the drive, if it sounds like it is clicking then it is probably not getting enough power through the usb. You should have received a cable with a split dual USB plug for extra power. Make sure that both large USB plugs are in the computer while the smaller one is attached to the drive, this will give it enough power to start working. If it is not clicking and has plenty of power then it could be that it is mapped to a drive letter that is already in use. Under device manager, (right click my computer and select manage then click on disk management) If you see the device in there then you can right click on the bar graph representation of the disk and select to change drive letter and paths. This will allow you to remove the conflict and have it show up again.
Jul 06, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
I would like to get photos from my phone to my computor what software do i need to do this. i already have the usb adaptor
You don't need software. Just open up "My Computer" while your cellphone is plugged in and it will show up as a USB thumbdrive, from there you can just copy paste the files onto your computer. The icon will be like your (C:) Drive but it will be another letter.
Mar 26, 2010 | Computers & Internet
Unable to access thumbdrive
It is possible that windows is trying to assign a drive letter to the thumb drive that is already assigned to another drive. You will need to go to Disk Management to see if the thumbdrive is showing up there and then try to assign it a drive letter.
Feb 07, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Don't have a problem, just don't know how to use flash drive
Simply plug in the thumbdrive into any available USB slot. It will show up in "My Computer" - generally named the same as the manufacturer of the drive.
From here it's all just drag and drop into the thumbdrive. You can make folders, or whatever you want as though it were a normal hard drive.
When you're done, right click on the drive in My Computer and select "Eject" - then you're done.
Jan 02, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Rescue data on optima attache 4G thumb drive?
Leave the thumbdrive plugged in to the computer and reboot.
Right click on my computer, click Manage, click on disk management, locate your thumb drive, right click and choose assign (or change) a drive letter. If it already has a drive letter, give it a different one as it’s already in use
Is this thumb drive USB specific? Some of the newer ones require a 2.0 USB port. It's possible you're plugging it into a 1.0 port.
open my computer and hit the f5 key on your keyboard for a refresh.. might not have posted.
try one or more of these
Jul 29, 2008 | PNY Technologies GeForce 6200 128MB AGP...
Not recognized on my computert
Try rebooting with the drive plugged in. You can also manually add the drive by right clicking on my computer in the start menu, and selecting 'manage', In the manage window on the Disk drives section, right click on the usb hard drive's partition and assign a drive letter to it. Hope this helps you :)
Nov 04, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Toshiba Satellite Pro 4600 Notebook Logo
141 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
