Question about Euro-Pro Faber Axia Isola Plus Kitchen Hood
All lights out on Faber Axia cooker hood
Bulbs are good but none of the lights work. Looking at bulbs someone has installed one 35w 12v bulb but other three are 20w 12v - maybe transformer was overloaded. Will not light with 4 correct 20w 12v bulbs but does give a sort of humming sound. Transformer is kaput I think but how do I find it and replace it please?
    New Friend:
Happened to me and I just cleaned all connections and it works!
Posted on Dec 08, 2012
  • 93 Answers
Faber # 508-358-5353
Posted on Mar 02, 2010
12v Spotlights flicker
Conversion from halogen to LED lighting is not a simple plug-and-play process. The power supply is delivering more than 12v because the LEDs draw less current. The flicker could be evidence that the LEDs are gradually breaking down.
Dec 09, 2016 | Kitchen Ranges
Humming halogens. I recently installed an electronic low voltage dimmer, 300watt DIVA, to my Kablelight system. I have 4 MR16- 12V- 50 watt bulbs. (200 watts total). When dimmed, the lights hum loudly. I...
Transformer hum with dimmers is a problem. Lutron may offer you an inductor to add to the wire to help. Replacing your 50w bulbs with 12w LED bulbs may help, too. Same light output.
May 06, 2014 | Electrical Supplies
Need replacement transformer
https://www.amazon.co.uk/s/?ie=UTF8&keywords=12v+lighting+transformer&tag=googhydr-21&index=aps&hvadid=223875610773&hvpos=1t1&hvnetw=g&hvrand=16005563945091609858&hvpone=&hvptwo=&hvqmt=e&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9046354&hvtargid=kwd-2661581121&ref=pd_sl_42m770poap_e
Jan 08, 2018 | Dishwashers
The light blew on my Beaumatic F60 extractor fan, thought the bulbs had gone so changed the bulbs, they lasted a couple of minutes before blowing again and then the fan wouldn't work also. I can't find a...
Look at the instruction/installation manual.
Are the bulbs 12volts or 120vac? If it is 12v there is a transformer that might be shorting to ground. If no transformer, the control panel or the control board has a short.
Mar 11, 2011 | Baumatic F60 Stainless Steel Kitchen Hood
When i fix bulb then it produce big light and then off.
Your voltage regulator is faulty. Alowing too much voltage to blow your bulb, unless the bulb is the wrong voltage of course.
Jan 23, 2011 | 2006 Hero Honda CD Dawn
My lawn lights stopped working, transformer tested ok. What could be the problem?
You checked that power pack is getting electricity.
Scratch a wire across both terminal screws and see if there is spark.
If a bulb burns out, and is not replaced, additional power can burn out other bulbs.
Power pack should be unplugged if bulbs are not burning since that can burn out power pack.
Change out a couple bulbs and then plug-in power pack.
Check connections where lights tie into wire.
My power pack was doing same thing, I bought another power pack from Home Depot to check my lights. All but 2 bulbs were burned out. I replaced bulbs and returned new power pack.. and then power pack quit for good a month later.
I found tips to preserve power packs:
1) Match wattage of bulbs with wattage of power pack
-15 each X 20 watt bulbs = 300 watts, so install 300Watt power pack
2) Installing a 500W power pack on 300W of bulbs will burn out bulbs and power pack.
3) Replace bulbs as soon as they burn out or other bulbs will burn out and power pack will burn out.
4) When working on bulbs, unplug power pack or it may burn out.
http://www.malibulights.com/guides_support/low_voltage_planning_guide/select_your_power_pack
Nov 14, 2010 | Intermatic Malibu 300W Power Pack...
I have a Euro-Kitchen 218 Series "Spagna Vetro" exhaust fan with four 35w halogen lights and two electronic dimming controls. Well, the lights all stopped working, although the control panel shows the...
DW, It is not the transformer. It could be the dimming controls. Also, instead of using a bigger transformer go in for CFL bulbs and reduce the load on the transformer. And contribute towards efforts to reduce global warming by using less electricity.
Sep 28, 2010 | Euro-Pro Kitchen Ranges
I have six 20w bulbs in an 120 system. They used to all work, but now #1, two works, 3,4,5,6 also don't work. I have checked the bulbs and connections to main wire seem fine. Do I have too many on...
There is a break in the main wire between the 2nd and 3rd lights. Has anyone been digging or working in the yard lately?
While the transformer is fully loaded, six 20 watt bulbs won't overload it.
Aug 23, 2010 | Malibu Intermatic Inc. ML121RT Low...
HID low beam headlight replacement for 2003 lexus es300
The HID bulbs are very easy to change, and can be bought online for much less than from the dealer. Check sites like xenondepot and Ebay for Phillips D2R (for reflector headlamps) HID bulbs and you can replace them yourself.
May 04, 2009 | 2003 Lexus ES 300
Euro-Pro Faber Axia Isola Plus Kitchen Hood Logo
474 people viewed this question
Top Euro-Pro Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you an Euro-Pro Kitchen Range Expert? Answer questions, earn points and help others
