Question about Karcher K2.26 Electric Power Washer
The gfci on cord keeps tripping
When i started it this year it came on briefly and then wont turn on ....
    President:
  • 1,489 Answers
GFCI's trip because theire is current leaking to ground. This often can be be caused simply by electrical components getting wet.
Or, it can be caused by a serious short to ground.
Fist, check to see if the inside circuits are getting wet from an internal leak. If so, fix leak, dry off components with a har dryer, try again.
If GFCI trips, it should be serviced by an experienced appliance repair person.
Posted on May 13, 2009
My gfci plugs on my predator 8750 wont reset unit still runs fine
Very small short can trip GFCI.... problem could be the generator, wire, cord. Or the GFCI can be bad.
Troubleshoot resources following link:
http://waterheatertimer.org/How-to-wire-GFCI.html#troubleshoot
Oct 31, 2017 | Electrical Supplies
GFCI wont reset, or, runs for 5 minutes and shuts off
Refrigerators should not be plugged into a GFCI outlet. The surge of current when the compressor starts up will trip the GFCI.
Apr 18, 2015 | Refrigerators
Had bad receptacle caused GFCI on ac window unit to trip fixed receptacle but GFCI wont reset or test do you have to replace cord on ac
If the GFCI won't reset , replace it. Make sure you have the new receptacle wired correctly before you do that.
Nov 17, 2014 | Heating & Cooling
WHAT PUMP RUNS FINE FOR A WHILE THEN IT WILL TRIP THE GFI...
the pump may draw more amps then the gfci can handle, check cord from pump near gfci at time of trip, if the cord is warmer than usual than the gfci is too low rated
Oct 02, 2014 | Electrical Supplies
My hot tub has been running perfectly until a few nights ago when the GFCI breaker tripped and now it wont reset
Either you have a ground fault or the GFCI is toasted. Turn off the power to the GFCI, open the box the GFCI is in and disconnect the output wires, close up the box, re-energize, and try to reset it again. This will tell you which problem you have.
Jun 04, 2012 | Cutler Hammer CH250 2 pole 50 amp
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jacuzzi wont turn on. It is making a hum but not working. Tried resetting GFCI many times, same result.
it sounds like the motor is burn out especially if the gfci keeps tripping when u try to turn on
Jan 12, 2011 | Home
Whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
GFCI Trips After an Hour
It is possible that the extention cord is the problem. Over time wires will heat voltage will drop. Along with the added distance on the code the voltage drop cause a drain and trips the GFCI. Try replacing GFCI and also try opperating without the extension cord.
Jun 12, 2009 | Panasonic NN-H764 Microwave Oven
Karcher K2.26 Electric Power Washer Logo
1,389 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
