Question about Philips 34PW8402 34" TV
No power front LED blinks 3 times stay on for 3 seconds blinks one time stay on for 3 seconds ... then blinks 3 times again...... any solution ?
hardrocko
  • 1476 Answers
SOURCE: won't stay on
RCA TVs do this when they detect an overvoltage condition on startup. The reason they shut down is to prevent x-ray issues. If your set is having this problem there is a problem in the x-ray detection circuit or it is not regulating the high voltage. Either way you will probably need to take it to a professional as it would beyond your capabilities to fix it.
Posted on Jun 23, 2006
  • 1694 Answers
SOURCE: Will not stay on.
tvtony = Install horiz driver upgrade kit for L04.1U chassis,
Part # 483531057673 + replace 47mf/25v cap in
horiz driver circuit..........................T.
Dannie = not the same chassis or exact symptom. Best if
you match info stream w / other 30PW862H tv's.
Posted on Nov 20, 2007
Kazong
  • 152 Answers
SOURCE: assistant
check your sleep timer settings thats the most comman prob
Posted on Dec 18, 2007
  • 52 Answers
SOURCE: Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Posted on Aug 14, 2008
  • 138 Answers
SOURCE: philips 42pf7321d/37 blinking power board question
The probleis with one of the maina boards and trouble shooting would have to be done to see which board is bad.
Posted on Aug 19, 2008
TROUBLE SHOOT LC-60E78UN TV
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 30, 2016 | Sharp Televison & Video
Need code for my oneforall URC-7140 for my Echostar HDS-600RS
If none of these work 0853 0396 0713 1323 1409 1413 try this,
The Search Method allows you to find the code for your device by scanning through all the
codes contained in the memory of the ONE FOR ALL. The Search Method may also work if
your brand is not listed at all.
Example: To search for your TV code: Switch on television (not on standby) and aim
your ONE FOR ALL at your TV.
1. Press and hold MAGIC for 3 seconds until the blue LED (any LED) stays on.
2. Select the corresponding device e.g. TV
3. Press 9 9 1. The blue LED will blink twice (showed by going out twice).
4. Next, press POWER.
5. Press CH+ (over and over) again until your device switches OFF.
6. As soon as your television turns off, press the magic key to store the code.
Congratulations! You should now be able to switch your device back ON and
control your device successfully.
In this example we will set Volume Control (VOL+, VOL- and Mute) to "TV
volume":
2. Press 9 9 3. The blue LED will blink twice.
3. Select the corresponding device e.g. TV.
4. Press and hold the magic key for 3 sec. The blue LED will blink twice and then
Switch off.
Now you have set the Volume Control to "TV volume". The VOL+, VOL- and
Mute keys will always control "TV volume" independent which device mode
key (TV, SAT, DVD or AMP) is selected.
WWW.ONEFORALL.COM 9
OFF
SSAAT/CBL T/CBL
This feature gives you the possibility to
set the Volume (VOL+, VOL- and Mute)
to always control a certain device (e.g.
TV) independent of which device mode
e.g.: Control your TV Volume in SAT
mode.
How to deactivate Volume Control
1) Press and hold MAGIC for 3 seconds until the blue LED stays on.
2) Press 9 9 3.
3) Press Vol +. The blue LED will blink 4 times.
All devices will send out their own VOL+, VOL- and MUTE.
How to remove a device from Volume Control
2) Press 9 9 3.
3) Select the device mode you wish to deactivate from Volume Control.
4) Press Vol -. The blue LED will blink 4 times.
The removed device will send out its own VOL+, VOL- and MUTE.
Search Method
Volume Control
You may have to press
these keys many times
(up to 150 times) so
please be patient.
Jan 13, 2013 | Televison & Video
Cant print anymore print counting is almost full. how to reset count
try this
Manual reset methods several EPSON Stylus Color. Actually there are two methods to reset epson printers counter, that is using software resetter such as adjustment program or SSC service utility or using manual by combination pressing button on the printer. If Reset using software resetter you can follow the way of usage the software but sometimes software resetter for the printer is not available. The only way to reset the printer if software resetter not available you can use manual reset.
The Following manual reset for some EPSON Stylus Color Printers:
1. EPSON Stylus Color
Pressing and holding ALT+FONT+LOAD+PAUSE buttons combination
press POWER button
Release all buttons
2. EPSON Stylus Color 300
3. EPSON Stylus Color 400, 600
Pressing and holding LOAD/EJECT and CLEANING buttons
press POWER button and hold it until you will see blinking INK OUT and PAPER OUT leds
Release all buttons
In 2-3 seconds time press LOAD/EJECT and CLEANING buttons again.
4. EPSON Stylus Color 440, 640, 740, 460, 660, 670, 760, 860, 880, 1160
press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
5. EPSON Stylus Color 680
Pressing and holding LOAD/EJECT and CLEANING buttons,
In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
6. EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons
press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
7. EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led
Release all buttons
8. EPSON Stylus Color 800, 850
Pressing and holding LOAD, CLEANING Color and CLEANING Black buttons
In 2-3 seconds time press and release CLEANING Color button, You will see leds blinking.
9. EPSON Stylus Color 900, 980
press POWER button, You will see blinking INK OUT led
Release all buttons
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
10. EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons
turn on printer.
Mar 17, 2011 | Computers & Internet
Toshiba A75 - S209 Power LED Blinks non stop, no boot
Here are some troubleshooting steps. From your description, my impression is a bad motherboard.
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jan 13, 2010 | Computers & Internet
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
Sony Wega KV-XF21M83 21" Color TV red LED flashing two times
mt sony trinitron power light is blinking from green to red twise and then pause for 3 seconds and then blinks again from green to red
Jul 05, 2009 | Sony FD Trinitron WEGA KV-32FQ70 32" TV
Ya...Ok
Good Day, egear00;
Did you try the DMD board? Other wise I'm still looking for solution.
big IRISH.
Aug 21, 2008 | Hitachi 60V500 60" Rear Projection...
Philips 42pf7321d/37 blinking power board question
Aug 17, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 34PW8402 34" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
