Question about GE Dishwashers
My GE quiet power plus will not completely drain at the end of the cycle.
I took the drain hose off and found that the check valve (washer/rubber flaper) was bad.This part keeps the drain water from running back into the dishwasher after the pump shuts off.Called my local parts suppy and you can not by just the check valve, you have to get the entire assembly at over 40.00. Thanks G.E. great design.
Posted on May 14, 2009
Jenn air quiet series ii
had a similar problem i just replaced the drain pump and it worked.
Aug 17, 2013 | Dishwashers
GE Washing Machine won't drain or complete cycle model # WBCH6240F0GG
The power line might flick. That's why not complete cycle.
Before do any repair, samply plug a alarm clock to the outlet that
the washer plug to. Leave there for a while about 1 day. If it blink that mean there a flicker on that line or may be some other line as well.
If power line is flickering. Fix the line (Do not fix the Washer!)
Mai Lor
Feb 25, 2013 | Washing Machines
My GE. quiet quiet power plus won't drain
This is normally a pump issue. check the following to combat this further..
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 11, 2009 | GE Dishwashers
We have a GE front loading washing machine model GCVH626OHWW that won't complete a full wash cycle. It normally stops part way through whatever cycle that we put it on and we have to hit the start button...
I would check to be sure your drain hose is hooked up correctly (not twisted/kinked or too far down your laundry drain) and the drain is not clogged or slow. Could also be a dirty pump filter on the washer. Check out the Troubleshooting Tips in the GCVH6260 manual- http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-90315-2.pdf
GE has instructions and a video for cleaning the pump filter-
http://products.geappliances.com/appliance/gea-support-search-content?contentId=16687
Oct 21, 2017 | GE Washing Machines
Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Jan 25, 2007 | GE 24 in. GSD1000G Built-in Dishwasher
Dishwashers Logo
1,133 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
