Question about HP PSC 1210v All-In-One InkJet Printer
Black cartridge won't print
The black cartridge on my HP 1210v printer won't work. It goes through the motions like it is printing but it comes out blank. I tried replacing the cartridge with a new one but it didn't matter. Color works fine. Am running XP, downloaded latest driver from HP too. Everything else on the printer seems to work fine. Could this be a problem in the electronics? Bad board or chip? Tried using the cleaning process in the software but it didn't help either. Got the printer from someone else, don't know if it worked for them or not. Any ideas?
  • Anonymous Feb 17, 2008
    same problem
Haaaaaaaaay i have the same problem what is with this piece of crap? someone help us
Posted on Dec 14, 2007
My hp photosmart 5514 won't print. I put in new ink-black and color- and it goes through the motions, but the page is empty
I just had this exact problem on my HP 5514. Black won't print after running out of black ink. New cartridge no good.
I tried everything-no good. I suspected the pinholes in the printhead were clogged with dried ink because I didn't change cartridge in time.
The fix that worked perfectly was when I hacksaw top off old black cartridge & removed all foam wicks so now I had a funnel(can see clear thru). I installed the cartridge & filled it with alcohol, printed page & did head clean; then printed few more pages. Problem cleared almost immediately. I then soaked up extra alcohol inside cartridge with paper towel. Removed modified cartridge & installed good one. I guess this could be done for colors as well. I don't know if this is a proper procedure, but it sure worked well for me.
Oct 05, 2012 | HP Photosmart 5514 e-All-in-One -...
The priter goes through the motion as always for printing but a blank piece of paper comes out. I have cleaned the print head but It still does the same thing. Do you have any suggestions that I might...
If you are printing using a color (not "black cartridge only" ) driver, yes, the printer won't print because it uses a "process black" when you use a color driver.
In other words it creates black using the 3 colors, and doesn't actually touch the black cartridge.
You will need to change the default driver to one that you create.
go into control panel, hardware and sound, devices and printers (win7)
right click the officejet 6500 (not the fax driver) and click printer properties
click the advanced tab, and click printing defaults
click the fast economical printing template.
Change "print in gray scale" to Black Ink Only
Click "save as" and name the profile "black draft"
click the newly created "black draft" profile, and click APPLY and OK
This will now be your default, and it will print in black and white while the color cartridges are empty.
Jul 29, 2011 | HP Officejet 6500 Wireless All-in-One...
I have an hp psc 1215 all-in-one. My black cartridge won't print. It recognises if I swap it out for a new one, and goes through all the motions. It registers the correct ink levels. The cradle...
The problem is not with the ink-cartridges. You've proved that, by swapping BLACK cartridges.
The problem is that the ink-jets that spray the BLACK ink onto the paper are clogged.
Thus, no BLACK ink reaches the paper.
Open the HP Printing Assistant, and open Utilities, and run a few "print-head-cleaning" cycles, to try to unclog the print-head.
Jul 19, 2011 | HP PSC 1215 All-In-One InkJet Printer
No black ink is appearing on paper
If this is an old printer. The nozzles might be clogged. A Q-tip with a little alcohol might get some of that dried ink out. Be careful it could get messy. Also see if your printer has a built in cleaning test. you might have to access the test from the printer tools on your computer.
Jul 30, 2009 | HP Officejet 5510 All-In-One Thermal...
hp nokia ce0168 code:059W7P3 imei 1:357802/06/817772/2 imei 2:357802/06/817773/0
Dec 26, 2017 | HP Officejet 7130 All-In-One InkJet...
Printing in Black
you should try to clean the ink cartridge's contacts (located on the bottom) with some metholated spirits and fabric cloth, softly...refer back to the user's guide, did u buy "real" hp cartridges???
Jun 01, 2008 | HP PSC 1210v All-In-One InkJet Printer
Printer goes throught the motions of printing, but what comes out is a clean page - no ink
Some of them do. Try going into the printer properties and disabling bi-directional support. This will not allow the printer to check. HP has set some printers to not function if its disabled, but hopefully yours is not one of them.
May 07, 2008 | Office Equipment & Supplies
I had the same issue when I replaced the printer and kept the old cartridges I had just purchased. The OK button I pressed was on the PRINTER not the PC. You dont say the model printer you have. Mine is an all-in-one J6480.
Oct 24, 2007 | HP PSC 1610 All-In-One InkJet Printer
Black stopped printing out. Dell 922 all-in-one ink jet.
clean contacts on back of blk cart and printhead with alcohol on micrfiber towel
Oct 14, 2007 | Dell 922 All-In-One InkJet Printer
HP PSC 1210 - The Print Cartridge Detected is the Wrong Type * The following message is displayed on the computer: "The color [or black] print cartridge detected is the wrong type" * The Check Print Cartridge light is blinking, and the Check Paper light is off. This problem usually occurs after replacing a print cartridge. Soloution:
Aug 05, 2007 | HP PSC 1210v All-In-One InkJet Printer
HP PSC 1210v All-In-One InkJet Printer Logo
59 people viewed this question
Ben Johnson
