This printer I have is taking a really long time warming up between print/copy jobs now, and keeps giving me the error "replace the TD Cartridge" which is relatively new.
Also, Is there a driver that will work with the Vista (64) OS out yet, or one compatible that will work for scanning? It would be nice to be able to use my laptop on this machine as well.
SOURCE: Sharp AL-1644 and vista 64
Using XP as a print server requires finding a compatible driver.
You can set it up by configuring the new printer as some other printer and creating a new port, using the address //myoldxpname/myprinter name and sharing your printer on the xp.
Problem is, I tried a couple of different drivers, such as an HP 4P and a different sharp copier. The sharp produced garbage. The HP driver printed the page, but in huge fonts. I don't have the time or patience to keep trying different printers. It was nice while it lasted...
SOURCE: error code E7-11
CCD drive circuit (CCD PWB, ASIC harness) trouble
Copy lamp lighting trouble (Copy lamp, inverter PWB)
OR the scanner shaft is dirty. Clean it and re-oil it with 3n1 oil.
SOURCE: Cannot scan using Sharp AL-1655CS
Make sure that you install the driver for your operating system. Check the stop of the scanner under copying table to the left.Do installing the equipment from panel of management. Check in "system" of the "panels of management" consumption resource of your printer and scanner. The Driver of the scanner is fixed from printer apart. Arouse update the drivers in accordance with your operating system.Windows or Vista or Linuks on put www.sharp.com
SOURCE: Sharp AL-1655CS
Have you replaced with a new drum cartridge? If so, does it still display error message? You have to simulate 24 sub 7 to reset drum .
SOURCE: On a Sharp AL-1631 copier I installed a new TD Cartridge and ????
That must be the drum cartridge symbol anyway do this; Press C, Exposure, C , Exposure in that sequence.The display will go out. Enter 24 press print 07 print. Then press C twice and you are done.
