Question about Garden
My Murray 4.0 HP Quattro will start but chokes out, I think the carborator is dirty or the air filter needs changing, but cannot find it.
  • 41 Answers
Follw fuel lines, it has to be at one end or the other.Then you can tell if that is the problem.
Posted on May 13, 2009
Backpack blower runs on choke only
replace fuel filter
air filter
spark plug
and clean the carborator jets etc...
change/change out the oil and measure the amount you put in
by the manual info look on the sthil site for the manual
Nov 13, 2013 | Stihl Magnum Br600 Professional Backpack...
Choke on carborator is broke
You car always remove the air filter and use your hand trick. meter the air coming in to the carb with you hand to get it started.(Less air hence "choke")
Nov 06, 2013 | Craftsman Sears Snow Thrower Manual Model...
I have a murray push mower 6-22271 briggs straton 4 hp. it start and then stalls . filter clean. choke fully closed when control is in full forwrd run/choke position. I pour gas in the throat and pull...
Your carburetor needs cleaned. It is dirty/has debris in it. If it has a bowl that is. If it has a diaphram (carburetor mounted on the fuel tank), replace the diaphram. They go bad.
I hope this helps get you going.
Jul 28, 2011 | Garden
17 hp kohler engine in a rider tractor 15 years old starts for about 3 seconds then dies after doing this for 15x or more it will finally start.What could be the problem? thanx
Could be several things. Change out your fuel filter with a new one. Could be a dirty float in the carborator as well. The choke may not be functioning properly (closing fully). Could also be sucking a little air through the gasket on the carb/motor. You may also be sucking a little air through a hairline crack in the fuel line. These can sometimes be hard to see and are usually going to happen at one of the connecting ports on the carb, filter or tank. You may as well out a new spark plug in to if you havn't already.
Nov 29, 2010 | Garden
I have a 1999 Audi A6 quattro, have just changed original fuel
You have to bleed the system, most likely air, or you blew the fuel pump fuse !
Aug 12, 2009 | 1999 Audi A6
Murray 20 hp
probally trash in the carb or fuel filter partially clogged. try replacing the fuel filter if no go the carb will need disassembled and cleaned.
Jul 14, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Can't pull choke knob up on my riding lawn mower
take the cable off the mower and clean it in a pan with solvent or brake cleaner spray. you can coil it up to fit the pan while soaking. afterwards, let dry --- if you have an air compressor blow it dry to help clean and dry it --- then oil it up with a light oil or wd-40, wipe it off, stretch it out, and work the cable again before you remont it. the cable will stick if it gets too dirty and has no lubrication. may want to buy a new cable but they usually can be cleaned and lubricated.
Jun 25, 2009 | Garden
Murray quattro ultra mower
Murray for the Mower and I imagine its a Briggs engine, go to Briggs.....If any other engine go to the maker of that engine.
Jun 04, 2009 | Garden
Garden Logo
291 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
