Question about Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White
When I heat up the oven i get a strong smell of gas and it fills
When I preheat the oven I get a strong smell of gas that fills the kitchen. It goes away after a while but it shouldnt be happening. Is there anything I can do? Is there any valve I can turn down?
  • miguel0483 May 13, 2009
    natural
  • Michael Masters
    Michael Masters May 11, 2010
    are you running LP or natural?
  • 6,784 Answers
Ok, your mixture is to rich at this time. you will need to access the gas pressure regulator and adjust the air to fuel mixture. add a bit more air and back off of the fuel a bit. this will correct this issue.
depending on the model, this may or may not be an option so, if you cant access the regulator and the burner assembly is not accessible as well, i recommend calling the local gas utility service tech to preform this adjustment. This rich mixture is very dangerous for you and your family and i suggest that this be corrected asap for you safety.
Please rate and god bless:)
Posted on May 13, 2009
Oven kicks on gas lights runs for 10 sec then beeps showing preheat is done then kicks off
I had to replace my igniter to get mine to work. I did it myself for $65.00 Mine the gas just would not stay on to heat up.
Mar 13, 2015 | Maytag Ovens
I have a Preway gas wall oven. Repair man said it was 55 years old. Guessing he couldn't know the exact age so late 50's/early 60's. It remains lit until about 3 or 4 minutes of preheating. Then the flame...
Try contacting them directly- I bet they might be able to help. Please don't take this into your own hands and attempt to rig something up, unless you're a professional. Especially when you're smelling gas during pre-heat. Here's their contact info:
Preway Service Inc.
Appliance Repair Service
27 Rocklyn Ave.
Lynbrook, NY 11563
(516) 593-1316
Aug 26, 2014 | Ovens
Maytag gas oven takes a long time heat and smells of gas.
Important---if you smell gas--I'd be very very careful---could be your control valve or lines to it are malfunctioning or leaking. You might have to call in an expert repair person. How old is the oven? Some preliminary checks you might make are: Do you have a pilot lite or preheaters on the unit? If a pilot lite, make sure it is lit. An unlit pilot lite could sometimes give the smell of gas if malfunctioning. If so, there is is a procedure for lighting the pilot lite--check your user or installation manual. If you have pre-heaters make sure they are lighting up. Normally you have one for the top broiler burner, and one for the bottom oven burner. Check your preheater(s) by selecting either broiler or oven and visually checking to see if they are warming up. After 15 seconds or so, they should be turning bright red. You will see some light coming from them. Check one pre-burner at a time. If they do not come on quickly, shut off the associated valve. Again, be very, very careful with any buildup of gas. It could cause an explosion. At the least it could make you sick.
Sep 12, 2012 | Maytag Ovens
When I turn my oven on to bake it goes on and starts to heat up during the preheat process. As soon as it's done with the preheat & goes to bake a #3 comes on my display and the button pas does not...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 23, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
We have the smell of gas when the oven is pre-heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
May 02, 2010 | Ovens
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
PCS 127 does not heat up. Fan and preheat start.
We were able to unscrew the plate that sits behind the latch. 6 screws I believe. Look towards the middle back-right side you will see a red switch. Click it twice. Before we put plate back we tested oven and it worked!!! Hope this info will help you. Dacor oven has been a real problem and I'm a kitchen designer. Will never recommend Dacor anything to my clients after many oven issues.
Jan 25, 2010 | Dacor Ovens
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
I have a whirlpool range that was purchased 04 2000. last week when i would set it to preheat 350 i was smelling gas and the oven was not preheating unless i set it to 500 and then it wasnt getting as hot...
Hello , sounds like the electronic ignitor has went out , they are not difficult to replace if your willing , the part is around fifty dollars and it should only take about a half hour to replace. please let me know if you have any other questions.
Phil
Jan 08, 2009 | Ovens
Strong Foul smell coming from oven only when I turn it on
do you have mice.they will tunnel in the insulation.you know what they do next,well then you heat that up and theres your smell
Dec 31, 2008 | Magic Chef 9122 Gas Single Oven
Whirlpool 30" Self-Cleaning Freestanding Gas Range - White-on-White Logo
280 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
