Question about Sony KDF-42WE655 Television
Green vertical lines on my 42 inch Sony Wega TV. They used to come and go but now are there all the time. They are about a 1/2 inch apart.
  • Bakdrjrk May 14, 2009
    I tried different outputs and unplugged the set with no improvement. The green vertical lines (about a hundred of them) are still there. They seem to be getting thicker or darker and are now blocking the picture.
  • 749 Answers
It looks your tv may have a burned out capacitor
Posted on May 14, 2009
  • 355 Answers
Sir do a power reseet ,turn off the tv then unplug it from the electrical source then wait for 1 minute then plug it in and turn it on if it doesn't work call sony customer serveice at 1800 222 7669
Posted on May 13, 2009
  • Rohit  Asthana
    Rohit Asthana May 13, 2009
    well try this before first
    Try changing the tv mode to video 2 or 3 (any video input with nothing
    attached). If the line remains even with no picture being sent to the
    TV, then it's a bad LCD, and will need repairs. Maybe you can post a
    picture with your digital camera so we can see what it looks like.
Sony ke42m1 plasma 1-1/2 black line down the middle vertically of the screen pic is otherwise clear started as a thin green line down the middle which would go away after a minute or so than the black...
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
Jul 31, 2010 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
42" red light on, dim light appears on screen. bulb just replaced
Sony has had alot of problems with the light engines
and your set is DLP. Call Encompass Parts Distrubtion for Part number and Price then go to E-Bay look under Electronics tpye in part number .I have found same Parts Alot cheaper on Ebay,some by as much as $300.00
you can Google website or call 1-800-638-3328
Mar 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
42 sony wega plama veritcal line
The PDP ( plasma display panel) is defect.You can look for badly soldered SMD resistors on the COF panels wich are located at the bottom of the screen.
Beware,the flatcables wich the resistors are located on are verry fragile!
Nov 02, 2009 | Sony WEGA KZ-42TS1 42 in. Plasma...
Green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Jun 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue Vertical Lines on the screen
It means the optical block is going bad. Contact Sony support. They will sometimes warranty these even after the 1yr warrany has expired. Have your model and serial numbers handy.
May 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
GREEN VERICAL LINES ON SCREEN
Had that once in a Panasonic plasma and it was the power supply.
May 12, 2009 | Sony KDF-42WE655 Television
42 inch sony grand wega
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jan 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
Sony KDF-42WE655 Television Logo
47 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
