Canon PIXMA iP5000Inkjet printer
Printer is producing prints with an overall greenish colour. I have run the cleaning programme more than the stated three times and performed deep clean at least twice. Nozzle check appears ok, although the colours are very light.Could it be the printer head is worn out? Printer is about three years old and gets regular but not intensive use. Cleaning is performed about once per month because if the printer is left for a few days banding occurs when printing is resumed again. The users manual only seems to point me in the direction of Canon servicing if the steps described in the manual don`t work.
Bryan Wood
  • Anonymous Mar 01, 2008
    I am having difficulty with banding in the printing of black.
Greenishness output is due to a lack of magenta (cyan and yellow combine to make green). The magenta print head nozzles are probably clogged with ink. Canon would have you buy a new print head ($75 ?). However, you can clean it yourself.
First get out some paper towels or heavy tissue paper (maybe napkins); something that doesn't give off a lot of lint is best. Also get a roll of cloth or rubber tape, duct tape works great. Get a bottle of something like 409 or one of those 'orange' cleaners that you use to clean your counter top. You'll know it is the right type of cleaner when the ink continues to come out of the print head during this procedure.
First you'll need to protect the circuit board area on the back of the print head by covering it with one or more pieces of tape. This is to prevent the cleaning fluid from getting behind the circuit board and shorting it out later when you place the print head back in the printer.
Place the print head straight up as it is in the printer on a folded, flat piece of paper towels while gently pressing down. The remaining ink should begin to appear around the edges of the print head as it is being absorbed. You'll have to continually move the print head to other clean spots on the tissue as it soaks in. The tissue helps by drawing out the ink (capillary action) and by keeping the individual colors from going into the other color nozzles. Make sure that the tissue you place the print head on is always flat and not curled or folded; this could damage the nozzles.
Spray the cleaner into the top of the print head where the cartridges normally reside. I will refer to this as the cartridge reservoir. Spray enough cleaner into the reservoir to cover the round spongy contacts that connect and align with the ink cartridges. This will soak into the print head just like the ink from the cartridges and begin pushing the old ink out the nozzles onto the tissue.
Continue squirting cleaner into the reservoir and moving the print head to clean spots on the tissue until only clear cleaner comes out onto the tissue. For the clogged nozzles this may take quite a while and lots of tissue, but the cost of these supplies is certainly less than the cost of a new print head! Don't run water through the print head!
Now carefully remove the tape and place the print head back in the printer and replace the ink cartridges. You don't have to wait for the cleaning fluid to dry and, in fact, you don't want to. As soon as the ink cartridges are in place the ink will begin flowing through the nozzles. Now run a alignment test and nozzle check to test out the system. Then resume printing those family pics, nudes, charts, etc.
Posted on Dec 11, 2007
How do i clean the printhead on my pixma mp750
If you open the preferences option for your printer there should be a maintenance tab with easy options for cleaning and checking the results. The alternative is to use the menu directly on the printer: 1. Press Menu twice to show "2. Maintenance" 2. The first option is NOZZLE CHECK 3. Press OK This should give you a print showing the current state of each colour. If there are any missing lines in 3eBK or lines in any colours then perform the head cleaning below. 1. Press Menu twice to show "2. Maintenance" 2. Press + to show "CLEANING" 3. Press OK Repeat the nozzle check after each clean. If not improved after three attempts try a deep clean as below (cleaning uses up ink) 1. Press Menu twice to show "2. Maintenance" 2. Press + twice to show "HEAD REFRESHING" 3. Press OK Repeat the nozzle check. If still not printing correctly there are various external solutions available to clean the print head such as http://www.printheadhospital.co.uk/canon-hp-printhead-cleaning-kit.html
Oct 17, 2012 | Canon PIXMA MP750 All-In-One InkJet...
I have a canon pixma 780. I hardly ever use colour yet the colour cartridges keep running out.
Every time you turn on your printer, it goes through a print head cleaning routine and the print head nozzles flush all the inks into the cleaning pads. This is why the inks are levels are dropping even though you have not printed anything.
Nov 02, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Why Does My Color Ink Run Out So Fast When I Am Printing In Gray Scale
When sending your print job to the printer, you need to be sure to select "black and white", otherwise your computer will use your color ink cartridges to produce your gray scale image/document.
Aug 12, 2009 | Canon PIXMA MP470 All-in-One Printer
Printer does not print colour
Do a deep clean and consider replacing the cartridges with OEM
Nov 16, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printer print blue instead of black
I have the same problem with my ip 5200, when printing a document in plain black.. I spoke to canon support and they suggested to save the .doc document as a txt file before printing. It works. Not too sure if this uses any colour ink to produce the black.
You can also set the printer on grayscale. However, the printer uses the colour ink to produce black.... hence printing in black & white becomes rather expensive.
If anyone has drivers to fix this problem please let me know...
Jul 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Green tint on photos
perform deep cleaning and nozzel cleaning from the printer properties
May 16, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printer
cleaning the ink tanks did help a lot but it's still not perfect, can age of the printer affect print quality at all
thanks so much, amanda
Mar 10, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
My canon i960 is printing only green
I had this problem. If I tried to print a black& white photo on to glossy paper, it would only print green. When I tried on to plain paper using the 'fast' option, it printed in black. The reason for this is, on plain paper it uses the black cartridge, but output to glossy photo paper using the 'high' option, uses the mix of colours in your colour cartridge. If one or more of your colours has run out, you will get a print with the ink left in the cartridge. Replace the cartridge or refill it & your problem is solved.
Dec 19, 2007 | Cannon Canon i960 Photo Printer
257 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
