Question about Kenmore 16226 Grill
Where is the Model number on my older Kenmore Sure Spark Grill
What I need is the heat deflector that goes over the "trombone slide" looking Burner. Any help? The Porcelin Deflector isn't worth a hoot on this grill.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 06, 2010
Green mountain pellet grill doesn't heat up. Put a new igniter in it. Goes from 3 degrees to 85. The auger works and the combustion fan is running. Any idea
Have you cleaned out the burner area. Every so often (especially if you see a lot of ash flying around) you need to take the grills and other deflectors out and vacuum the burner area out. You may be full of ash.
Sep 17, 2017 | Grilling
How does the sping go on the grass deflector?
U need a diagram ver hard to explain but try this line up your spring in the grooves of deflector put ththem agaibst the deck in between whereyou will nect slide the long pin that goes through the spring and the deflector you can find a diagram on sear parst online web site type in your serial number and model or look in your manual it takes about 2 minsto installjust position correctly and slide in pin ask for second pair of hands
Joe
Oct 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need new burners what is part number and where do I find them
Mine all fell apart too. I went to Walmart garden center and found some one size fits all burners. They go in real easy and are made well. The burner is like a trombone, it slides so it fits many different sizes. The burners are $10 apiece and well worth the money. These will probably never need to be replaced.
Jun 30, 2010 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Need to replace burner tubes on a Ducane grill. How do you do this? How do you get the old one off? I don't have a manual anymore.
First call Weber to receive the Warrenty burners for free. Have model and serial numbers ready. They can be found on one of the doors. Here is what I did for my Ducane model 30400042.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Jun 07, 2009 | Ducane 30400042 (LP)
I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Apr 16, 2009 | Ducane 30400042 (LP)
How to change the burners
Mar 30, 2009 | Ducane 30400040 Stainless Steel Grill
Gas burners heat unevenly
I had a similar problem. I took off the burner heat deflectors and seen gaping holes in the burner tubes. Get your model number and serial number and call Weber. Most Ducane grills have a 5 year warranty on the burner tubes. They will ship them free if under warranty!
Nov 10, 2008 | Ducane 30400042 (LP)
Burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Jul 04, 2008 | Ducane 30400040 Stainless Steel Grill
Replace burners
remove the cooking grates and the 5 pieces ubnder the grates covering the burners from the grill. Next remove the 4 screws on either side of the control knob panel pull it away from grill and pull the burners out from inside the grill. DO the reverse to install new burners
Apr 19, 2008 | Ducane 30400042 (LP)
Kenmore 16226 Grill Logo
570 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
