Question about Dishwashers
Miele G570 dishwashher tripping ELCB at end of drying cycle Continues to trip for about an hour even if switched off at the button. Must be plugged out to stop ELCB from tripping.
  • 460 Answers
This information will help U  please copy n paste
http://www.youtube.com/watch?v=nr6tIO5iNSc
If you need more assistance please contact us.
Was this helpful?
Posted on May 13, 2009
My tefal keeps tripping elcb in fuse board what could be wrong
Next time it happens and it trips.. use a dry towel to unplug kettle, just in case.
Is the base wet? Check the kettle for cracks. Check the cable. Is it damaged? Try replacing the fuse in the plug. Is the steam that the kettle produces affecting lighting or other electrical items around it? Try moving the kettle to a different location.
Aug 05, 2015 | Tefal Irons
My domena steam press keeps tripping switch
It has a serious fault, the trip tripping is saving you from a electric shock.
By the way if your ELCB is a oblong brown or black box with a yellow or orange test button its way outdated I recommend you get it changed for a modern RCD (much safer)
Oct 17, 2014 | Vacuums
Split ac of "LG " will run in normal condition for 3 to 4 hours but when the i switch off the unit ELCB will suddenly tripped, i have checked the pressure and current drawn by the unit it found normal,...
hi there this problem is normally caused bye a bad or should i say dry joint in your DB board check that especially your neutral wire isnt loose
Mar 05, 2014 | Haier Heating & Cooling
Tripping ELCB (RCB)
sounds to me like a short circuit in the heating coil circuit. One would have to ohm out the coils.
Jan 30, 2014 | Miele T8005 Tumble Dryer
Tefal easycord keeps tripping the elcb
The ELCB tripped whenever the plug switch is on.
Jun 08, 2012 | Tefal UltraGlide Easycord FV4256 Iron
Machine keeps tripping out when starting wash cycle - electrics have been checked by electrician - no problems- have managed to get it to spin but not to wash
Hi
The washing machine is obviously drawing too much current for the breaker to handle. This could be due to the washing machine drawing more that it should or because the breaker cannot handle the current the machine needs, coupled with the other machines on the ring main. If the fuse on the plug of the washing machine does not blow, then it could be that there are too many appliances on the ring main. The fuse on the machine may not blow however, if the breaker has a faster blow time than the fuse in the plug. Try plugging the washing machine into another ring main. Or try plugging out all the other appliances on the same ring main and test it out.
If the ELCB (Earth Leakage Circuit Breaker) is tripping only when the washing machine is running then something in the machine is faulty.
One common problem is the heating element. Over time they tend to crack and when the water gets in, the ELCB will trip out. This can be problematic to diagnose as offten the element will only trip after a period of heating. Bottom line, if it is tripping the ELCB then it is dangerous and should be fixed before any further use.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 05, 2011 | Creda W120VW Front Load Washer
Maytag model GS2126PADW is tripping the ELCB. It will run for about one hour before tripping. After tripping, it trips the ELCB every time it is turned on. However if left off for an hour or so it can be...
The ELCB ( Electrical Leakage Circuit Breaker) is designed to detect any leakage of electrical current.
When the current leakage occurs, the ELCB then trips the electricity supply within a fraction of a second of the leakage being detected, before the magnitude of the current reaches a lethal level.
Therefore any possibility of serious injuries due to electric shock to persons who are in contact with the electrical appliance at that particular moment is minimized. Have a licensed Electrician check out your outlet and an Appliance Technician check your refrigerator if outlet proves okay.
Dec 05, 2010 | Maytag Refrigerators
Dryer tripping electricity saftey switch
You probably have a shorted heating element.
May 15, 2007 | Miele T1322C Electric Dryer
Dishwashers Logo
252 people viewed this question
Top Dishwashers Experts
