Question about Homelite Mighty Lite Lawn Trimmer
Starter rope HOW TO INSTALL STARTER ROPE ON HOMELITE MIGHTYLITE TRIMMER?
  • 41 Answers
First, i will take that the rope is in the front. If so, you will need to remove trimmer shaft,throttle assembly, so you will be able to remove starter housing.
Posted on May 13, 2009
Hello. I Need to Fit a New Starter Cord to a Homelite Strimmer, Can You Give Start to Finish Instruction's. UT No is 20586, Ser No is HM2130442. Thank's, Mike.
Hopefully the website will translate.
Remove throttle handle from shaft trying to keep all parts in one side and once removed place together and install a couple of screws, remove shaft from part no 42 by loosening screw no. 43, item 45 has either a allen head or star head screw in it will probably loosen ccw. Remove item 45, remove item 46 should be arrow to show which way to turn you will need to use copper or brass pin to hit with hammer to remove to prevent damage. Now remove item no. 41 and you are at the starter cord. You will now have to remove spool no 51 and notice how rope is wound if possible, remove old rope install new rope place spool back in place to where it catches spring as it should now wind in same direction as rope wound about 5 turns hold and run rope through eyelet of starter housing. Now install keeper 52 with screw 53.
Sorry link did not work just go to link below and type in your ut no.
then select homelite.
https://www.ereplacementparts.com/homelite-hlt17c-ut205
Sep 20, 2017 | Homelite Garden
How do I replace the pull starter cord
How do I replace Graeme, Check the attached links,instruction and videos on starter rope replacement. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starter Repair
String Trimmer Recoil Starter Replacement Echo String Trimmer Repair Part...
How to Wind Up or Rewind Starter Pull Rope Recoil Spring on Yard Pro 130A...
Part 1 3 Changing the Recoil Rope on Craftsman Model 358 791030
Apr 01, 2016 | Garden
How to replace starter rope on homelite 26b blower
The starter rope is buried in the bottom of the unit. So you have to split the upper and lower halves of the blower to get to the starter pulley. The rewind spring sits right beneath the rope pulley so you have to be careful not to pull out the spring or it will be next to impossible to put back in! I would suggest pulling a video from an online parts source or youtube for details.
Be safe and good luck!
Sep 30, 2014 | Homelite Garden
Starter rope is stuck, will not move when trying to start the trimmer
Smack the the f%%k out of the reel try to get some w/d oil on it then get a new coil reel when smacking watch for string whip
May 31, 2014 | Homelite Factory Reconditioned 26cc...
Pull cord will not rewind
  • 1
    Turn the Homelite chainsaw so that the bar and chain are laying flat and the starter cover is facing up. Loosen the four starter cover screws by unscrewing them counterclockwise with the screwdriver.
  • 2
    Take the starter cover off of the engine. Turn the starter cover over to work on the pull starter. Pull the rope out about 6 to 8 inches.
  • 3
    Twist a loop into the end of the rope. Insert the intersection of the two ropes into the notch on the upper flange of the pulley. Rotate the loop back and forth until you notice the recoil spring has disengaged. Unwind the rope from the pulley. Cut off any old rope if you need to replace it with a new rope.
  • 4
    Unscrew the screw holding the pulley to the starter cover using the screwdriver. Take the pulley off the starter cover. Turn the pulley over and remove the recoil spring cassette from inside the pulley.
  • 5
    Inspect the spring inside the cassette to see if it is damaged or overstretched. Replace the recoil spring cassette if it is broken. Lubricate the post on the starter cover using about a dime-sized amount of engine grease.
  • 6
    Put the recoil spring cassette back into the pulley. Set the pulley onto the starter cover and tighten the screw down with the screwdriver. Wind the starter rope back around the pulley in a clockwise direction.
  • 7
    Leave about 6 to 8 inches of rope unwound. Form another loop at the end and insert the loop into the notch on the pulley. Rotate the loop back and forth until you notice the tension is set on the recoil spring.
  • 8
    Remove the loop and place the starter cover back over the engine. Pull the rope out 6 inches and tighten the starter cover's screws using the screwdriver. Release the rope and it should automatically retract
  • hope this helps
    John
    Sep 09, 2011 | Homelite Garden
    Homelite 25cc model UT20002A. How to repalce starter string?
    Remove the shaft assembly at the motor, there should be one or two screws on the boom clamp. Remove the four screws holding the starter housing on. Inside the front of the housing is an air baffle you don't have to remove and the starter pulley. Remove it carefully, you don't want the spring to come out of its container. Remove any vestiges of the old starter rope and install the new one with no more than three or four windings depending on the thickness of the rope you bought. Install the pulley in the housing with the rope through the slot in the pulley so you can wind it a couple times to catch the spring and start the tension. It should be tight enough to just pull the string back into the housing. Feed the rope through the hole in the housing then through the t-handle and tie a knot so it won't pull back through the handle. Put the housing on the motor, no screws yet, and pull the rope out to make sure nothing is binding and the rope retracts fully into the housing. If it's too tight use the slot in the pulley to take one winding out. If the t-handle dangles, add a turn to the pulley. Reassemble housing and boom and you're ready to go.
    Aug 23, 2010 | Homelite Mighty Lite Lawn Trimmer
    Starter pull rope will not not retract. how do i fix
    take off pull mechanism, take out rope and recoil spring, reinstall starter rope
    Jun 02, 2010 | Homelite Consumer Products MightyLite...
    Troy bilt string trimmer starter rope
    you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
    Aug 06, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
    Homelite Mighty Lite Lawn Trimmer  Logo
    291 people viewed this question
    Top Homelite Garden Experts
    Jim Parker
    Jim Parker
    roeb
    Mike Squire
    Are you a Homelite Garden Expert? Answer questions, earn points and help others
