Question about Dryers
GE Washer the model# is DDE7200SBLAA will not start
Was working just fine and all of a sudden would not turn on. I have checked all the circuit breakers on the house, turned them off and back on but still nothing. Doesnt even make the timer noise like usual when not turned on.. I cannot afford a new dryer, so anyone can help that would be GREAT!!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Buy a used working one or log on the "WEB"
Free-Share and get a free dryer.
Vitally
Posted on May 15, 2009
All of a sudden, my washer won't turn on at all! No lights, no nothing. The outlet is fine and the breakers are, too. Any ideas?
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Mar 19, 2015 | GE Washing Machines
Ge Gtup270EMww dryer will not start. washer works just fine
If you can hear the motor running, and the drum not turning, it could be the belt. I would check the wall outlet to make sure that you are getting 220 volts, not just 110 volts. After this, the parts are possibilities get more complex and more expense, i.e. circuit board, timer, or motor, and it would probably pay to get a repairman in rather than just trying to change parts.
Dec 11, 2014 | GE GTUP270GMWW Laundry : Laundry Centers
GE washer model SWLP1100D error FF
Loss connection in the door motor safety circuit
Recommended to replace control
Nov 24, 2012 | GE Spacemaker WSLP1100D Top Load Washer
GE cooktop ignitor jgp
Look for a short in the wiring (usually white wires running to the ignitors) or a loose ground wire. (usually green)
Jul 02, 2012 | GE Cooktops
GE Model WDSR2080DBWW Washer spins very fast sounds like it going to run thru the wall
If it really is doing that, you may have a serious electrical problem in your washer's location, particularly if the washer had been working fine, and "all of a sudden" started this.
I would take a long extension cord, and plug it in elsewhere, that you know is exactly the right voltage, witnessed by (for example), a light bulb that is burning the correct brightness.
I would plug the washer in the this extension cord, and see if then runs the way it used to..
If you have incorrect voltage at the plug for the washer, you really should shut down the whole area until it is checked by an electrician, as a fire could be imminent.
Be blessed.
Sep 25, 2011 | GE Washer And Dryer Stack Bracket Kit...
GE Dryer model DCL333EAOWW that will not start
I have a GE (Model #: DCL333EAOWW) Dryer that will not heat up properly and the timer does not work
Aug 14, 2009 | GE Dryers
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
GE Triton not working
Jitterbugclu-
I may have the solution. Husband just turned off power to dishwasher via circuit breaker. Waited around 30 minutes.
Restored power and Triton came back with normal lights.
I just ran a cycle and all was well. Hope this helps you.
My fingers are crossed because I don't know what happened but did read on another site that this should be the first thing you try before expen$ive repairman.
Reply back if it works!
TootieC
Dec 25, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Washer will not spin
Could be a bad clutch or transmission. I would either call a tech or get a new washer (these newer GE models don't seem to be very reliable, go for a Whirlpool/Kenmore model next time). Here are breakdown diagrams for your washer: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230151 Hope this helps, APP Tech
Aug 07, 2006 | GE WJSR2070B Top Load Washer
Dryers Logo
71 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
