So i go tomy local area connection properties and its asking formy tcp/ip address dont know what that is
To solve the DNS problem follow the steps given from StackOverflow.com . If you need to check the website DNS Query visit the site WhoisXY.com and get it.
It should be dhcp, click the box that says automatic, if there's something wrong with your ISP's DNS server you can manually set it to 8.8.8.8 and 8.8.8.4 which are google's DNS servers
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
SOURCE: Toshiba laptop running Vista loses connectivity
The problem is not Vista, the problem is the Netgear. I have seen this happen time and time again with both Netgear (primarily) and D-Link (often). That's why I *only* recommend Linksys.
Worst case - go buy one from Walmart (yes, they have 'em). Hook it up and see the difference. If, somehow, the problem persists, take it back, and you've lost nothing. But I'd bet (as they say down here in the South "dollars to doughnuts") that's your problem :)
Hope this helps - remember to rate :)
SOURCE: M300 toshiba connecting to locally, not connect to internet
Dear Shifsa,
Considering the fact that you are trying to connect to a wifi connection which of course is unsecured,
here are some workarounds..
1. Uninstall the wireless card driver.
Go to device manager > click on the + sign beside network adapters > right click on the wireless adapter and select uninstall. Restart the computer it should get reinstalled automatically.
2. try disabling or uninstalling the antivirus or internet security software. you can later on again download the a free software from www.hippo.com
Hope this helps.
Regards,
Anup
SOURCE: Hello My problem is that
The devices that have a yellow ? against indicated that device drivers was not installed.
You can download any/all the Windows XP device drivers for your model laptop from the Toshiba WEB site from their download page.
Make sure you enter the model of your laptop so you can get the correct drivers.
Use this link :-.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
SOURCE: my toshiba laptop is a black screen asking for a password.
hi friend,
If you have lost or forgotten the XP administrator password, first reboot Windows XP in safe mode by re-starting the computer and pressing F8 repeated as the computer starts up. Then (in safe mode) click Start and then click Run. In the open box type "control userpasswords2" without the quotes.
You will now have access to all the user accounts, including the administrators account and will be able to reset the lost password.
Just click the administrators user account, and then click Reset Password.
You will need to add a new password in the New password and the Confirm new password boxes, and confirm by clicking OK.
All done, you have recovered the lost administrators password!
Source(s):
http://www.hsinlin.com/tips/lost_passwor…
http://www.goitexpert.com/entry.cfm?entr…
http://www.download.com/Active-Password-…
If it’s a BIOS password then there are several ways to do it, on older Toshiba's there is a “key” that you put in the parallel port to unlock it, or you can remove the BIOS battery (with the main battery and the mains out) then short out the pins for a few seconds (sometimes you have to strip down the base of the laptop to get to it, maybe half to an hours work if you know what you’re doing). If it has been written to a fixed memory, you’re stuffed and need to contact Toshiba with proof that it’s yours.
If it’s an XP / Vista user account password then you can either log in as Admin using safe mode (F8), or, as happens sometimes) you’ve removed/disabled the Admin account or forgotten ITS password as well then you need to clear the user account password file (ther are a number of programs that do this, I know which ones I prefer, others may have different choices)
If you’re still stuck let me know.
thank u for using fixya
regards,
sivaranjini
SOURCE: my toshiba a205 s5804 is asking me a bios password
remove ac supply and battery from the laptop.. and press power button for atleast 30 sec.. it reset the CMOS memory.. this is what toshiba technical support person told me to do when i called to them way back..
