Question about Dremel 300 1/40A "Multi Pro" Rotary Tool Kit
I cant loosen the head on the dremel 300. When I push the button and try to remove the head all I can hear is some clicking and it just wont let go the attachment
  • 3 more comments
  • boris_kos1 May 13, 2009
    Yes I know that, I disassembled one of my old dremels.
    I cant take it apart because they've put hexagon screws to hold it together and I don't have a wrench that small..
    Maybe that metal button got bent and it cant engage the hole any more? Can I buy a replacement for that?
    alright... I made 1 of my wrenches smaller using my old dremel and finally opened my dremel 300. Inside I found a small metal rod that looks like it used to have a pointed tip but now its so flat it cant engage the hole. Tnx 4 the tip, I'm going buy this part tommorow.
    Cheers
    tnx for trying scspriggs but if I make the rod any shorter I wont be able to push the button all the way down and I'm not really sure how the original point looked like. I'm not taking any chances... gonna buy a new one tommorow and replace it.
    Thanks!
  • Samuel Charles Spriggs May 11, 2010
    I'm sure you can buy that part, but it probably just needs some bending/moving back into position.
    Just a suggestion: Those are torx screws. A set of torx screwdrivers is not that expensive. Man, they sure do come in handy.
    The button engages a hole in the motor shaft which keeps it from spinning when you turn the wrench on the chuck. There is something causing the button not to slip into the hole in the motor shaft. You'll have to take the tool apart and find out what's causing this.
    Can you take it apart and tell me what you find. Be very gentle, there are some parts which may fall out when you do this.
    President:
  • 1,489 Answers
Another suggestion: you could put a point on that rod with a grinder or a file, or a dremel, and it's good as new.
Charlie
Could I get a "problem solved" / "fixya" rating on this -- there are icons at the bottom of this posting I believe.
thanks...
Posted on May 13, 2009
Cannot release tool from Dremel 300
I had a similar problem with a router, the best way to do it is to get a clamp, a strong metal c clamp, not too big but big enough to fit chuck into, line one side of clamp up with button and the other on the chuck. tighten the clamp as tight as you possibly can so it presses and holds the button in, and does not slip. Then use a wrench or whatever tool you use to undo the chuck. if this does not work, try spraying some WD40 on and leave to work for a few minutes.
Feb 21, 2014 | Dremel Tools & Hardware - Others
I need help attaching the new bit to the dremel model 1100
Hi leigh abear...
I will send you to the dremel website where you can watch a video on the dremel model 1100 and it will explain how to use it and change bits,cutters,ect.
Do change your bit without going to the website push down on the large button on top to lock the tool, and then you wil loosen the bit holder bu turning it anticlockwise to loosen the grip on the tool you have in the bit holder.
Please take time to rate me
http://www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=1100
Sep 09, 2011 | Dremel Garden
Change sandpaper head on dremel motor tool
if your talking about the barrel sander there is a screw on top that you loosen and the barrel will slide off put the new one on tighten screw and your good to go
Jan 09, 2010 | Hand Tools
Changing the sanding drum cant get it on the rubber drum
have same problem. take retianing screw and washer off, remove from arbor and roll the rubber between fingers with a mashing force. this can take a little bit but i ussualy only have this problem when i dont loosen the set screw and dont use it for awhile.
Oct 12, 2009 | Dremel 300-N/55 300 Series Tool Kit
I have a Dremel 300, i think, lol.. standard Dremel... To losten the collet nut, you have to press down a button that locks the spindle so you can loosen it.. the spring and *** have stipped and it won't...
call dremel and ask for the part need you model number so have it ready Dremel Service Center Dremel Authorized Service 4915 21st Street 4631 E. Sunny Dunes Road Racine, WI 53406 Palm Springs, CA 92264 Phone: 1-800-437-3635 Phone: 1-800-275-2052 1-262-554-1390 1-760-327-3003
Jul 07, 2009 | Tools & Hardware - Others
I inherited a Dremel Pro from my son who passed away...
you should have a little wrench that came with it
and on the neck of the dremel there is a shaft stop button
push the button and manually rotate the dremel head till
it clicks then hold the button and use the wrench to loosen the bit
Mar 27, 2009 | Dremel 300 1/40A "Multi Pro" Rotary Tool...
Help. Cannot remove the nut on the dremel
HELLO ,you must keep your thumb on the push button while trying to loosen the nut it sounds like your pushing the pushbutton in and then letting it go as you try to loosen the nut , i also have a dremel and i made the same mistake when i first got my tool , Hope this truly helps you get it off , I thank you for letting me try to help you Sincerely Glenn
Mar 04, 2009 | Dremel 400 1/6 120V Xpr Rotory Tool...
Dremel shaft lock spinning
Trying to fix a similar issue. The pin that gets pushed in by the button (and returned by the spring) seems to be fine. The hole in the rotating shaft that the pin fits into, however, is in the wrong place, so the pin never goes into the hole! All I need to do is somehow pull the whole front part of the shaft out about 1/16th of an inch, and it'd be fine. I just can't seem to budge it though. Any tricks, anyone?
Nov 13, 2008 | Dremel 300-N/55 300 Series Tool Kit
Trouble Changing Attachment
Looking down on the collet end of the dremel, push red button and take pliers and turn locking nut in a counter-clockwise direction.
Oct 03, 2008 | Dremel Mini - Mite Cordless Rotary Tool
Dremel rotary tool removing shaft of attachment
They can be stubborn. I would take padded pliers to the nut, and not focus on removing the shaft until the nut is loosened. Be careful not to damage the nut. You may also try spraying a light lubricate at the base of the nut and hold the dremel upside down so that some could possible get behind the nut.
Sep 27, 2008 | Tools & Hardware - Others
Dremel 300 1/40A "Multi Pro" Rotary Tool Kit Logo
680 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
